does not want to slow down
Old Jun 26, 2015 | 09:10 PM
bentleyapb's Avatar
I have a 2000 f150 5.4 the intake went bad i replace it. Everything went well but now the truck does not want to slow down i can be going down the road at high way speed and put the truck in N and the rpm jump 500 then come down then when i put the truck back in drive then it slows down. What could make it that? Please help the mpg has went down a lot. And the idle is about 1100 after i start driving.
Old Jun 26, 2015 | 10:29 PM
Possibilities:
Sticky throttle cable or weak return spring
Dirty/sticky throttle body
Large vacuum leak
Sticky IAC
Have you checked the OBD2 for codes?
Old Jun 26, 2015 | 10:39 PM
bentleyapb's Avatar
I cleaned the throttle body. But the throttle cable does seem to have some slack how can i make it tighter? And i have spayed starting fuild around the engine and don't find anything but I'm getting ready to do again. No cheack engine light.
Old Jun 27, 2015 | 11:56 AM
Roadie's Avatar
Are you sure that it isn't acting normally? I believe the throttle is set up so that it will not close quickly for emissions reasons.
Old Jun 27, 2015 | 01:59 PM
The throttle is pure mechanical, there's no dashpot to hold it open. The IAC will open to gradually return it to idle, and it should be a lot less than 1100 rpm. SOMETHING is keeping the throttle itself open or the IAC is not working correctly.
Old Jun 27, 2015 | 08:51 PM
Roadie's Avatar
glc, Thanks for the explanation. When I lift the throttle on my 02 the truck takes forever to slow down. I suppose it is the high gearing.
Old Jun 27, 2015 | 10:21 PM
It's the IAC doing that if the throttle is released. As a test, disconnect your IAC and see how fast it slows down.
Old Jun 28, 2015 | 08:32 AM
projectSHO89's Avatar
There is way more to it than "high gearing", like what transmission you have and what gear it's in as well as the computer-controlled idle control system.
