View Full Version : 1997 - 2003 F-150
- Headlight HELP
- Blown spark plug repair question
- Drivers window does not role down..?
- 98' F150 Brake Conversion
- Will this lift work?
- starter replacement 4.2 L 98 F150
- Need new S Clip
- Dash lights out
- 2003 4.6 mpg
- 03 Crew Cab Rear door window seals
- Cylinder 1 not firing
- Think mechanic screwed up
- ext. cab with crew bed on std. frame
- seriously getting pissed
- Mystery Plug
- '04 5.4 expy swap to '02 f150???
- Upgrade time
- 4x4 and heater control lights
- true blues back in action!
- Need Help, Im at a dead end!!
- rattle on highway, pinging? Dirty injector?
- Replacement exhaust
- 2001 F150 4.2 Manifold Oil Leak
- Detroit True Trac Limited Slip in front diff? PROS AND CONS???
- 99 steering wheel swap
- new idler arm...drives like a dream
- Odometer broken on my 97
- What would you pay for this truck??
- Heater core hoses
- brake problem IM LOST!
- 2002 F150 Slowly fixing and Modifying
- Head Gasket replacement how to?
- 245's would probably look stupid... ???
- 1995 ford xlt150
- 1998 F150 Heater blowing Luke Warm
- Body Mount Question
- My Truck
- Is going to 4.10s in an 02 2wd screw the right gear ratio for my truck ?
- Just some updates:
- Back seat will not flip up
- How do I remove gas from my 00 150
- Birthday/Christmas ideas help??
- sending unit for 00 lightning
- 1998 4.6L missing on 1,2,4
- P0452 and fuel pump/startup issue related?
- 2000 F150 5.4 Stumbles at WOT
- New enigine crazyness!
- not turning over, lights flashing, clicking
- Looking for some help
- 1997 f150 thinging of buying, What to look for.
- 99 f150 5.4 ....elecrical issues draining the battery
- Newbie here, need help with P0420 and O2S
- Fuel rail ticking?
- Brake Light Problem. I am hating life
- Oil change question
- 02 F-150 HD Supercharged edition problems
- Help diagnosing steering issue
- Cut Heater Core Hoses
- equipment console
- truck probablems
- Really stumped with this po174
- Stock stereo w/after market subs?
- Wheel Spacers
- Seat Mounting
- No heat
- 12 yrs old and going stronger.
- Is this normal? Stock air intake with Gotts Mod
- Bak Flip instaled- *pics
- What gauges should I use
- Bad news for TrueBlue
- First truck i have ever had!!! what should I upgrade??
- Supercrew Owners
- PTM entire stock bumper
- 97 F150 4.6L 2wd brake issue
- ECU on a 98 4.6 liter
- 1997 Ford F-150 Torque Converter Removal Question
- pulling questions
- Pictures: 97-03 F150 with Rivet Fenders
- Lighted runnig boards
- 22x9.5 & 24x9.5
- 97 F150 automatic loses 3rd gear
- Raptor Clone Engine Swap Build without breaking the bank.
- Doing the IMRC stuck open p1538 fix, and have a few questions…
- A/C Compressor Froze up
- Electrical issues
- 2002 4.6 PCV questions
- step 1 - remove oil pan (grrrrr!)
- Gauges or instrument cluster.... show what u got
- inlet manifold 4.6lt
- speed control cable (cruise control) 1997
- are 2000 F150 2006 rear end compatible ?
- Ford Mechanics?? Fuel Delivery Issue...
- Whats your least favorite or most disappointing mod.
- Will this setup work?
- 1997 f150 4.2l speedometer not working??
- Door lock
- 2002 F150 2WD transmission fluid change?
- My trucks progress.
- Interested in a Lightning motor swap?
- 2002 Flareside Extended cab looking for lift and more...
- Project build "Silver Surfer"
- Will an 03 4.2 fit in my 97??
- Anyone boatsided their 97-03?
- Efan Question
- Expedition center consoles
- Block Cooling Plugs help
- 5.4 Throttle Body cover
- Front right tire squeak noise
- 2000 F150 intermittent starting for a year, now won't start at all
- 99 4.6 rushing water sound in heater core
- running a -6 offset with no issues, can I run a +1.00 ?
- Which yr 4.2L V6 will fit my 98?
- Winter storage planning!
- Hit a deer tonight, thank god I drive a ford!
- Valet Switch 2001 F150
- Will Mud Flaps Foil 33's
- Remote start bypass module
- rear dif. size
- fuel pump question
- Cruise/Door Locks symptoms
- 5x135 to 5x5 Conversion
- Will 33s fit?
- Overhead Console Swap. WIll it Work?
- 2001 5.4 Serpentine belt
- GEM or Body Control Computer
- ABS light code question
- Seat swap
- Squeaking sound in front passenger side wheel well
- SuperCrew rear door handles up front?
- add overhead compass?
- Power steering pump replacement
- Pitman arm
- revs at idle
- truck running lean on bank #2
- Did my heater core just blow?
- Lift help
- Electrical help!!
- 4.2 to lightning swap? possible?
- Rough Idle
- 2002 harley f150
- how can i adjust a/f?
- f-150 Boss 5.4?
- Foglight mod
- f150 help 4.2
- 2002 f150 engine issues
- Coolant system Leak
- Noice while accelerating from 50mph to 60mph
- Driveshaft length
- another steering wheel swap question
- Recommend some pads, rotors, and shocks.
- where to tap into to feed a turbo
- Turn Signal Nightmare
- no fire to coil
- I have a question
- New harley headlights in
- 2003 F-150 Leaf Spring Hanger Help
- E cut outs
- My 2001 4.2 Build Thread
- Help with bed!
- Catalytic Converter Replacement question
- Let's see those aftermarket grills!
- What gear ratio to go with?
- Running Boards Rattle
- Clink / clunk noise on 1-2 shift.
- Lookng for a heavy duty front bumper or brush guard, need help finding
- Annoying front end noise - diagnosis assistance requested
- 2000 F150 Turn Signal Issues Even After a New Harness
- Ready Lift Leveling kit Questions!
- 5w/20 vs 5w/30
- Trans leaking before/after pan drop
- RBP grille for 99-03 f150
- 2002 4x2 lift. HELP
- Replace Wheel Bearings??
- 4x4problem No way.
- Wrecked my truck - have parts swap / compatibility questions
- Should I tackle this project? Used truck purchase
- 03 f150 fuel problem ?
- Got my 24s on!
- 5.4 spark plugs...Timesert 'em all?
- A new use for 5.4 coils
- Window keeps slipping down
- Coolant Leak. At My Wit's End!!!!
- cup holder leds
- looking for a camper shell
- 2002 f150 idling problems when warm
- 4.6L Issue
- whinning A/C engine almost stalling
- Removal of bypass heater metal line in engine valley on 5.4
- Any one know where to get front brake backing plates?
- who here loves their 4.6 over the 5.4
- no love for the 5.4 - intake manifolds
- Bedliner Compatibility
- Engine won't fire
- recall department wont approve my recall repair..what can i do??
- Not an F150, but...
- Front end parts
- Weird headlight problem
- Entered my truck in its first car show!
- 1998 4.6 F150 4x4
- 03 f150 4x4 kickout?
- Need Help Finding a NOS OEM Part
- serpentine belt replace
- Help my fuel pump has no power
- Seat Swap
- Clay bars, polishes and waxes
- Body lift install ?s
- Dpfe voltage
- I saw Coy's KR
- Caliper sticking
- Code p0406
- Headlight Switch
- 2003 f150 acting weird
- Heater Core.
- Clunking/bumping noise and vibration
- 1997 wrecked to rolling
- Having 2 Issues: Starting and Turn Signal
- Tune-up, Tires, Shocks, Battery, Tires and Brakes
- Why I need Traction bars
- 4 wheel drive problems (4wd)
- 1000th Post
- Two questions (2001 F150) - 1. Noise - 2.Ball joints
- running smaller tires
- New shots of the truck
- Cab clearance lights
- a F150 related painting question
- 6 speed auto in our older f150's, can it be done?
- Drive Shaft Question
- Looking for 2000 Black Honeycomb Grille Insert
- 01 f150 4.6 Idling rough
- Cool Idea's that you made possible.
- 02 F-150 Starting Problem
- Another crazy spark plug adventure
- Anyone have these heads?
- Any tips for painting headlight trim?
- should I buy this parts truck
- Rough idle in gear
- Look what I found:(
- well looky here!
- Baja Eliminator Install
- professional products fuel rail .
- F-150 versus new Durango crash
- super charger question
- Duplicolor Shadow on my 02 Harley Edition
- Front end swap ideas
- Will these fit?
- Rock and A Hard Place.
- 4.6 Supercharger
- WTF? Power Steering Fluid is green?
- Rear end "clunking"/creaking?
- Exhaust Manifold R/R - A PSA
