Think mechanic screwed up
I have a 2002 f150 4x4 with the 5.4l. My rear right Axle Bearing started going bad. Since i just moved i didn't have all my tools so i brought it to a mechanic in the new town to get it fix. I had them do both sides. I told them when i dropped it off that it had the 9.75 rear end. When i went to pick it up they informed me it was a 8.8 so they used the bearing for the 8.8. Do i really have A 8.8 rear end or did they screw up and should I be worried about having the wrong bearings in there? Thank you
Of the rear end? If so I won't have a computer to get on until i get back from hunting camp. Will try to get a picture later tonight
You can count the bolts holding the diff cover on. If 12, it is either a 9.75 or 10.25. Since you did not say whether you have the 7700lbs GVWR, you can assume 9.75. And as stated, I know of no 5.4 with an 8.8 rear.
It isn't the 7700lb gvwr. So i believe its the 9.75 rear end. Is there any side effects to having the axle bearing meant for a 8.8 rear end when my rear end is a 9.75... I just checked and it has 12 bolts on the diff. Cover..
Doesn't matter, same part # (1225) thelariat02. However, bearing quality can be up to you if you purchased third party.
Ok i don't know what they used. They just told me when i picked it up that it was A 8.8 rear end and it ended up being cheaper.. Thank you for all the help. If they are the same part then i won't go back to them to get it changed..
same diameter yes but 9.75 is 34 spline and 8.8 is 31 spline. The 9.75 are also shorter. 10.25 is 35 spline.
