ECU on a 98 4.6 liter
Old Oct 21, 2012 | 11:59 PM
ghaze88's Avatar
I'm thinking about installing a chip on my truck and it says it wires into the ECU but I have no idea where it's at any help would be greatly appreciated thanks
Old Oct 22, 2012 | 01:54 AM
wilderthing's Avatar
I am prob wrong but for some reason I believe it is above the passenger side kick panel. Hopefully someone will give you a definite answer. If it wasn't 2 am I could probably give you a more definite answer lol.
Old Oct 22, 2012 | 02:03 AM
jbrew's Avatar
It's referred to as the PCM, more so and wilderthing has the location.
Old Oct 22, 2012 | 09:22 AM
ghaze88's Avatar
I appreciate it thanks
Old Oct 22, 2012 | 09:29 AM
Do NOT install a "chip" on a OBD2 vehicle - get a PROGRAMMER.
Old Oct 22, 2012 | 10:56 AM
ghaze88's Avatar
There is a website that has performance chips for 70 bucks and it says it wires into the ECU with 2 wires I was wanting to get something I can install myself but what would be a good affordable programmer that would increase MPGs HP and torque I pull a landscaping trailer and have heavy loads
Old Oct 22, 2012 | 11:29 AM
1997 lariat 4.6's Avatar
get a bigger truck... you wont get (enough) power from a chip/programmer.
Raptor05121's Avatar
Do NOT get it! Its a scam! Those things are nothing but a simple resistor between two wires.
Old Oct 22, 2012 | 12:01 PM
There's no magic $70 device that will improve anything. You need to spend several hundred dollars to make any kind of meaningful improvement, and even a programmer and tunes won't do all that much. You need legitimate power adders and a regearing.
Old Oct 22, 2012 | 06:17 PM
lightning_clone's Avatar
Don't get it you'll regret it
Old Oct 23, 2012 | 05:49 PM
ghaze88's Avatar
I just got the truck but I appreciate all the input
