Ready Lift Leveling kit Questions!
Old Sep 24, 2012 | 02:37 PM
forrest51's Avatar
I have a Ready Lift leveling kit on my 02 Fx4 and I have LT295/70r17 nitto trail graps and the truck is level but I was wondering if I could crank the new torsion keys any more because I would like the truck to sit a little higher in the front. I did not install the leveling kit so I don't know if they been cranked all the way but I just wondering if any one knew if I could crank them anymore. By the way I do have some rubbing when I turn all the way to the right. The inside of the left front tire rubs on some of the parts inside the wheel well, but so far it hasn't seemed to cause and damage and I dought it will.
Thanks for any advice yall have.
Old Sep 24, 2012 | 02:41 PM
pizzaman711's Avatar
I wouldn't crank past 2". Aftermarket keys are the worst, but since you didn't install them you probably don't have the factories to swap back in to see how high you can actually go. If you don't know how high it is the only way to really see is to crank both sides all the way down, and then crank them up until the truck is raised 2" on both sides, and then most likely get an alignment.
Old Sep 24, 2012 | 02:48 PM
forrest51's Avatar
I thought about doing that and I might do since you suggested it, I just need the time and personnel cause I might mess something up, but I do still have to old keys, the guys gave them back to me after they installed the new ones, thanks for the advice though
