03 f150 fuel problem ?
got an 03 f150 that starts and idles fine but when i put er in gear it seems to misfire It will barely run when under load The truck was ran out of fuel a\nd has sat for 3 months I installed a new fuel filter no difference the fuel pressure is 30 at idle and 40 under load
Any ideas??
Any ideas??
ncb, I moved your thread to this forum hoping you might get a better response. It's quite possible you don't have a fuel problem at all. There are several other things that can cause what you describe.
I think 30 psi is adequate at idle, but possibly 40 psi is too low above idle. I know a 2004 truck should be 30-45 psi at idle. Your fuel pump may have been damaged by running out of gas. I think that is a possibility.
- Jack
- Jack
