4.2 to lightning swap? possible?
Old Oct 3, 2012 | 10:11 AM
MiamiChris1021's Avatar
Smile 4.2 to lightning swap? possible?
Hey all, I have been looking around and have always seen different responses to if you can swap a lightning engine into the 4.2 trucks. I have heard that the motor mounts are located in different places, anybody know if this is true or not? Also since it will be going from the 4r70w transmission to the r100w the driveshaft is shorter if i am right any way to deal with this or do i need to custom fabricate it? Anything else I need to know about?
I would have a complete lightning truck that was in an accident that i will be using parts off of to do the swap just would like to know what i am getting myself into or if I should even attempt it? Thank you all for your feed back!
Old Oct 3, 2012 | 10:15 AM
Blue-02-2wd's Avatar
I'd say if you have a donor truck then do it! swap everything from the harness to the rear end if possible. If worse came to worse and you needed to change motor mounts(which i do not think you do) then i'd say go for it! You should have every part you need then for an easy install!
Old Oct 3, 2012 | 10:25 AM
That's what i am thinking too but I have a ext cab while the lightning is a regular cab so the different wheel base would be a problem for me or am i wrong?
Old Oct 3, 2012 | 10:28 AM
As far as i know only in the drive shaft but Im sure u could find one via salvage yard or have one made for a few hundred bucks.
Old Oct 3, 2012 | 10:29 AM
FordGunsMerica's Avatar
all the more reason to get a custom driveshaft.
Old Oct 3, 2012 | 12:37 PM
coobies5's Avatar
why not just fix the lightning with your current truck.....
Old Oct 3, 2012 | 12:51 PM
That may be a bit rough depending on the damage - the L is a reg cab Flareside and he has a Scab.
Old Oct 3, 2012 | 01:19 PM
coobies5's Avatar
just throwing out a suggestion....doors will fit if they are damaged, along with the front end
Old Oct 3, 2012 | 01:23 PM
The lightning had a Salvageable title and the truck i have now is a clean title, the interior on my truck is in perfect condition while lightnings beat up pretty bad. Also i prefer having the extra space in my truck since i do use it all. I figured that it would just be a lot easier to do the swap.
Old Oct 3, 2012 | 01:39 PM
1997 lariat 4.6's Avatar
swap everything down to the PCM. make sure you have all the wiring components hooked up to the motor, and add anything you need to.
Old Oct 3, 2012 | 01:43 PM
should i use the same wire harness or the one that is on the lightning? I am planning on switching it out since mine is bad but would like to be sure.
Old Oct 3, 2012 | 01:53 PM
swap.
Old Oct 3, 2012 | 02:28 PM
coobies5's Avatar
you have to swap the wiring harness to run the 4r100
good luck on the swap, it's going to be pretty labor intensive!
Old Oct 3, 2012 | 02:35 PM
thats what i was thinking about the harness aswell. Labor intensive is what i like actually, it helps learn plus a real man/women know exactly what is underneath the hood and knows exactly how it works.
Old Oct 3, 2012 | 04:30 PM
coobies5's Avatar
yup, well you're going to have your hands full
new motor mounts, trans crossmember, fuel pumps......and a lot more odds and ends
