Headlight Switch
Headlight Switch
I need to know how to get the headlight switch out of my truck. I know that Alex did a how to but I tried it and it didn't work. Can I just pry it out or is there a certain way to do it? Thanks guys
I always pried mine from the slot in the lower part. Make sure to tape of the edge on the dash around it or use a rag as the paint chips/gouges real easy around the edges when popping them out. This pic from rockauto shows the clips on one from a side shot..
http://www.rockauto.com/getimage/get...80_PRIMARY.jpg
1.) Turn the headlights on
2.) Pull the **** out (it doesnt matter if you have fog lights or not)
3.) Underneath the ****, where you just pulled out, is a little slot. Use a flathead and pry off the ****.
4.) Turn 180* and install back on the headlight switch
5.) Turn lights back off, and on again
6.) Pull and the whole thing should come out.
