2002 headlight switch removal help
Old Jun 10, 2011 | 06:49 PM
2002fx4122's Avatar
Im in the process of fixing my gear shift indicator and I need to get the instrment panel out to get the indicator out of the bottom, but for the life of me I can not get the headlight switch out to get to the last bolt behind it. My truck is a 2002 FX4 lariat with auto lights and fog lights
Old Jun 10, 2011 | 07:03 PM
pry it out, takes 1 or 2 seconds
http://www.youtube.com/watch?v=EvWrehBENPc
Old Jun 11, 2011 | 02:43 AM
Raptor05121's Avatar
http://i89.photobucket.com/player.sw...s/MOV02935.flv
Old Jun 12, 2011 | 12:31 AM
2002fx4122's Avatar
Which one is it? I afraid im going to break the face plate off of the assembly by trying it patman's way. I have the part of the dash thats infront of your knees off so I can reach up and push the clip in but it still isn't poping out. Is there some sort of clip on the top too?
Old Jun 14, 2011 | 01:51 PM
yes there are metal clips, you need to get behind the thin face and pry on the body of the switch itself
Old Jun 14, 2011 | 03:18 PM
c_ulater's Avatar
When I pulled mine out, I did the same as Raptor.
Old Jun 14, 2011 | 04:05 PM
jethat's Avatar
Raptors vid is the right way. prying it out could damage the clips..
Old Jun 20, 2011 | 07:55 PM
2002fx4122's Avatar
I tried it raptors way and ended up breaking my **** so now when I try to pull my fog lights out I can't, and I still didn't get the assembly out
Old Jun 20, 2011 | 10:42 PM
What part did you break it out at? The screwdriver part?
Old Jun 21, 2011 | 10:22 PM
2002fx4122's Avatar
when I used a screwdriver to pry it off it came off and when I went to put it on I noticed It went on to easy and when I pulled out for fog lights the **** came off. After a closer inspection the piece that the **** attaches to broke, so the **** is fine but the assembly needs to be replaced
