Engine won't fire
Old Sep 15, 2012 | 02:31 PM
ihilani's Avatar
Engine won't fire
Help. Parked my 97 f150 4.6 a couple of weeks ago, it was running fine. Tried to start it up this morning and it wont fire. Starter just spins with no sign of spark.
Where do I start?
thanks all (again)
ihilani
Old Sep 15, 2012 | 05:58 PM
jbrew's Avatar
Where do I start?
thanks all (again)
ihilani
First, - I don't understand the last part, - yea, it's sort of important. Does the engine crank, turn-over at all? If the starer just spins, the starter gear is out or you have flywheel damage.
If you checked spark and the engine turns over without producing any. On that 97, replace the crank sensor and she'll fire right up.
Old Sep 15, 2012 | 05:59 PM
ihilani's Avatar
Okay, so I checked the fuel cutoff switch switch in the passenger foot area, found the fuel rail was pressurized with fuel, so it seems that I don't have a spark going to the plug.
Where do I begin?
thanks for any advice
Old Sep 15, 2012 | 06:29 PM
ihilani's Avatar
Yes, the motor turns over. But no sign of an ignitition. Is there an easy way to test for spark?
thanks
Old Sep 15, 2012 | 07:00 PM
Missdiabolical's Avatar
Help me figure this one out please
I have a 1986 f150 that won't start. I put a new starter relay, alternator, and battery in it. It is a 6 cylinder. It tries to fire over, but then I turn the key and nothing. I'm stumped at this and need good help. Also when I put a screwdriver in the starter relay I get spark, and it tries to start.
Thank you in advance.
Old Sep 15, 2012 | 09:39 PM
JCR 56's Avatar
thanks
Try changing the crank sensor like jbrew said and see what happens.
Old Sep 15, 2012 | 11:45 PM
Bluegrass's Avatar
Missdiabolical, your in the wrong forum.
This is 97 to 03 model years.
You have a straight 6 cylinder.
It has a completly different ECM control.
If it tries to fire, sounds like it's flooded.
Hold throttle wide open and crank it to see if it cleans out.
Old Sep 18, 2012 | 06:58 PM
ihilani's Avatar
Okay, I took the afternoon off to change the crank position sensor as recommended by Jbrew. Thought it was going to be a monster but done in 1.5 hours and started right up. Could be my immagination but it seems to run better than before.
Thanks Jbrew
