Will these fit?
Well if i'm right 12.50 width is like a 315mm tire, and as far as I know a leveled 4X4 for our year can only clear 305s, maybe even only 285. I've lifted and leveled my 4X2 to the same level as the 4X4s and I know I can fit 285s but after that width becomes an issue.
I could be wrong or misremembering though.
im guessing stock wheel with it being a 33x12.50r17
Read this:
https://www.f150online.com/forums/su...ml#post4671301
Read this:
You can clear 35x12.50's on a leveled 4x4, so you should be good. The only thing is that mud grapplers have very large side lugs, so you will probably get some slight rubbing on the corner of the valance and the sway bar at full turns.
i was just skeptical on the 12.5 inch tire on the 7 inch rim. But DHGFX4 is doing it just fine. but yeah, when the sidewall hits the sway bar it may feel a little bumpy because of the wall tread.
im interested in seeing how they look once mounted though. post pics after.
