View Full Version : 1997 - 2003 F-150
- 4.6 windsor to 4.6 romeo swap
- Front brakes?
- 5.4l build quality and questions
- Grinding sound when putting in gear
- Seat Leather codes?
- 5.4 motor swap help
- My truck has spells....
- ac compressor
- Need some help..
- Reverse Lights Not Working
- Bilstein shock help, please
- Fuel pump?
- 2003 f150 2wd leveling kit
- diagram of freeze plug location 99 4.2L
- fuel problems
- Emergency Brakes not working at all
- Door lock not working
- Newbie, questions on her first 1999 f150
- Back At It!
- Weird exhaust?
- 98 4.6 to 99 5.4l swap w/ pats
- intermittent misfire
- 97 2WD lower ball joint procedure
- When replacing lower ball joints
- Pinion Angle Experts needed:)
- 03 4.6 issues
- Intermittent Cranking difficulty
- 2000 f150 power windows not working
- power door locks not working!
- Oil Not Sticking to Dipstick?
- 2 wheel to 4 wheel abs??
- Engine belt idler pulley broke off motor..
- TIRE SMOKIN' 1998 NASCAR F-150 Edition
- Battery disconnect - Radio problem?
- WHERE does it go? (engine compartment)
- 32.5" tires with 2-3" body lift (opinions needed)
- Brake light on
- Ford Ignition Coil Pack Heat Failures & Misfires When Wet
- Broken steering part on lifted 97 f-150?
- Diagnostic tool for 2001 F150 V8?
- 20in wheels
- How-To: Fix 98/98 Broken Odometer Worm Gear
- Rats got into my truck HELP!!!
- 2003 ford V10
- Recommended boltons for my new 4.6 crew cab
- 97 expedition power windows in 2002 f150
- A/C stops working when the vehicle stops/starts suddenly
- I'm back! 2001 f150
- How to Diagnose a bad A/C compressor ?
- 97 Odometer not working
- clunking noise from the rear when i accelerate hard
- Haunted drive train
- Fuel pump replacement questions
- How to put a 12" sub in a regular cab F-150
- Help: Flareside bed Accessories????
- can someone please help me 02 f150 4x4
- Need help finding wheels
- New exhaust
- Swapping out back seat in 2003 F-150 King Ranch captains chairs for a bench seat
- 1997 4.6 PCV valve connection (on passenger valve cover)?
- Upgrades and Questions
- Front hub part??
- 2000 f150 4x4 lift questions
- 4.6 No start but starts and runs fine with some starting fluid
- 2000 f 150 fuel pump
- Engine issue
- My 97 F150
- 4wd standard height?
- wont start
- Travel Note
- 03 F150 EATC climate control blinking
- No start, dashes on the odometer, theft flashing
- Need Opinions on 4x4 build
- Will a lightning front bumper fit in my 98 xlt?
- 2003 9.75 rear end- need axle help!
- Crazy a/c
- Please direct to a post on install of trailer brake Control
- photoshop help
- Sounds like machine gun...
- 4.6 no start
- 4.6L won't fire after rebuild
- Removing starter on a 2000 f150 V6
- Need help on superduty mirror conversion 1999 f150
- Front bearing torque??
- 98 Reg Cab XLT Mirror Options Help/Advice??
- Keyless Entry Code
- Looking for trasnfer case rear tailshaft.
- Issue with ordering lights and model.
- Rocker panel rust - need some opinions
- Truck shuts down when I try to crank
- 2000 F-150 heater core drain
- efan question
- alarm going on
- should i tow it?
- Tire Smokin' Tuesday: Final Burnout for a Ford F-150 Clunker
- 2002 King Ranch won't start
- new headers?
- 2003 F-150 4.6 no start
- 2002 ford f150 lariat cruise control not working
- Gear shift issue - need help!
- front suspension part
- Emergency Brake stuck.
- Trying to figure how to turn my fog lights on with out having to run a switch?
- need help with replacing radiator support
- Center jump seat for 2002 SCrew?
- '99 F-150 to Lightning conversion...please help!!
- Complete 4R100 Swap Notes
- 98 F150 4.6 V8 intermittent fuel problem.
- 2002 F150 tires
- exhaust leak, manifolds to headers
- Mid Travel F150 KIT
- Another Trailer Wiring Problem - 02 F150
- Dealer said I had metal shaving in oil pan
- What should I expect when I lift my truck?
- PO Bank 171/174 O2 sensor guaranteed fix?
- Need help
- Need options to improve gas mileage
- What just happened?
- 2000 F-150 miss fire cylinder 2
- Hidden Fogs and Mesh Grill Project Complete..
- Rocker panels rust
- Speedometer won't register above 17 mph
- 99 f-150 engine idle.
- Airbag problem - Code 24
- 1997 F150 Airbag light stays on constant
- Best stock exhaust option
- F250 cng back to gas
- Lightning exhaust on 4.2
- My truck wont start! Help me!!
- Should I ???
- 4" lift on 35's?
- 97 f150 4.6l p0302
- 2000 f150 engine wont turn over?
- 1997 f150 cruise help
- **stuck in park**
- Rear power window motor replacment?
- no power locks
- WOT computer is confused
- 02 SCrew 4x4 - sounds like ppl doing it on an old mattress
- "permanently" locked tailgate
- Replacement Ignition key
- Just Lowered The Back More And P0171???
- 97 F150 Stuck Cruise Control While in Driveway
- Odd Beeping
- A/C Compressor lines
- New mods (pics)
- 01 f150 AC issues
- Big Brake Kit advice
- High idle issue
- Cruise Control Not Working
- I want to make my truck louder?
- rough country block lift
- 250K boom - what should I replace, flush, change, check, ect?
- Seats
- seats?
- How to Flush the coolant system
- truck mods
- 98 f150, STICKING FRONT DISC BRAKES
- Key Fob
- This one is weird
- Level kits?
- Just getting back on here. Anyone ever painted there leafsprings
- turn signal troubleshooting. brake overides turn signal.
- Are my mirrors pre-wired for led signal mirrors?
- gas tank strap mounting - recall
- Torsion Replacement 98 f-150
- Bed Covers Interchangeable????
- A/C compressor seals(Help)
- 8.8 rear differentail questions
- 02 5.4 Rough Idle and code p0403
- ABS Light from H__L
- 2001 5.4 screw randomly dies while driving, pats keeps from restarting sometimes
- Window came off track. Help!
- Rear axle help
- It Has Been Awhile
- coil on plug question/recommendations
- "Tow" setting on Tuner- What to expect?
- Trying to find parasitic drain, question about meter reading
- 03 f 150 4x4 driveline squeal.
- 2002 f150 fx4
- Little ways to customize my F-150?
- Chip/ programmer help
- O rings
- Two Bosch fuel pumps, which is correct?
- 97 F150 idle issue
- What belt?
- Trouble is sticking brakes, transmission, or ?
- Difficulty installing level kit?
- Gas Mileage
- Failed Emission test texas
- check engine light
- 01 rear Bumper ?
- 99 super cab xl
- Passenger side window goes down, not up
- 4low problem...please help
- Changing Fuel Pump, Before Putting Bed Back On Inspection
- first big project
- Header recommendations! 00' f150 5.4
- New tires for the f150
- 4x4 problems need an expert opinion
- 01 f150 misfire code
- 5.4L V8 'oil consumption'?
- In need of new shocks
- Fuel filter change
- catalytic converter help
- Looking for new Bumper??
- 2001 f150 4.6 - What is this part?
- Tires?
- New shocks for 6" Fabtech lift
- Gage problem?
- how much clearance?
- 2007+ dash swap!!
- WTH is the oil filter?
- '97 Ford f-150 4.6 rough idle and check engine
- 99 F150 P1151 Question
- Oil filter adapter removal revisited
- Truck will not start.
- bad temp sensor or what?
- 2003 F150 that wont cooperate.
- Truck started missing
- Lost caliper mounting bracket bolt twice
- Need part number for valance panel
- Looking for opinions
- 2000 f150 2wd lift help/suggestions
- wont start
- Two or three bolt Starter????
- lack of power
- Cam Lobe Position for Cylinder 1 and 5
- New Ignition Cylinder. Truck wonts starts.
- cabin blower not working
- hotchkis rear shocks for 97-03 , Question..
- Need Help with Proper Installation of Timing Chains
- Question for you guys: Alignment cam kit
- Dimmer fuse blowing after I put in a new radio, Help
- tire size under cranked torsion bars?
- A "lazy" startup?
- obd reader won't work
- 02 f150 rear axle
- 1997/1998 Odometer worm gear repair
- Throttle positioning sensor Install
- 2000 F150 pic request
- A/C vents
- Replaced my 4x4 Decals
- Specific Power help
- pet cover
- harley grill, 745$ from lmctruck WTH!
- Intake gasket failure
- cross over gasket / windshield wipers
- does this intake gunk look bad?
- 1999 F150 Fuel gauge problem
