2 wheel to 4 wheel abs??
Old Aug 26, 2014 | 07:47 PM
fordf150farmer's Avatar
Quick question about the abs on our trucks... My 97 only has rear abs. I did some looking and i found what looks like the plugs you would plug the sensors into on the front. I am not too surprised as ford used basically the same wiring harness between trucks.
I am due for some front end work and was wondering if i bought the hubs with the sensors, what else has to be done to make the 4 wheel abs work? Some fuses? Or does the proportioning valve have to be changed as well?
If it's totally out of the realm of possibility that is fine, I just thought if i was going to have it apart any way.... why not make that change if it's possible...
Anyway, thanks for any thoughts and comments!
OH! the truck is a 97 reg cab 4x4 off road 5.4
Old Sep 13, 2014 | 12:24 PM
1997extCab_Fl's Avatar
Our system has one ABS sensor but it controls (releases) all 4 wheels if it detects the start of a rear skid. if your back brakes are bad or have air in the lines the front will skid all day because the rear is not starting to skid.
I am almost to the point of installing a proportioning valve and adjusting it so I can have good stopping power front and rear, then re install the ABS fuse.
also these look pretty.
http://www.wilwood.com/BrakeKits/Bra...no=140-12824-D
