1997 4.6 PCV valve connection (on passenger valve cover)?
Old Aug 19, 2014 | 12:29 PM
divinity's Avatar
1997 4.6 PVC valve connection on passenger valve cover
My PVC valve has 2 ports. The bottom port is connected but the top is not. Where does the top port plugs into? It is not capped. Truck makes a loud hissing sound and sucks in strong from the top port. When I plugged the top port with my finger, truck seems to run smoother and quieter.
Help. I searched the web and cannot find any info or pics.
Old Aug 19, 2014 | 02:08 PM
ishootstuff's Avatar
You should have a sticker under the hood with the vacuum diagram like this:
Old Aug 19, 2014 | 10:30 PM
divinity's Avatar
I see the diagram, but I don't understand it.
Old Aug 20, 2014 | 02:37 PM
Maybe someone put the wrong PCV on it. That diagram only shows a single connection. Cap off the extra port and drive on.
Old Aug 21, 2014 | 12:09 PM
jbrew's Avatar
Yea, it's the wrong valve. I believe you're using a cold climate system PCV valve on an engine that doesn't have the system. A motorcraft PCV is definitly what you want , but yea, you need a standard (one port) 233/238 with that engine...UNLESS your CCS was by-passed for some reason ? Probably not.
Old Aug 21, 2014 | 12:14 PM
jbrew's Avatar
BTW- Those diagrams don't help much lol. Shows you main line vac. The PCV valve is just a general (non specific). It stands alone in the diagram because it gets vac from the engine (cam cover).
