Sounds like machine gun...
Old Aug 11, 2014 | 06:15 PM
itchibahn's Avatar
My 2003 F-150 Supercrew was working fine then was parked for few days.
I unlocked the door using my remote, and it unlocks, then re-locks itself, unlocks, then re-locks, few times all by it self!!!! When I opened the door, there was continuous clicking sound coming from either in the dash or under dash, it was hard to tell. I had to disconnect the battery to make them all stop.
After reconnecting the battery, If I lock and tried to unlock, the same problem repeats.
At last, I tried to crank the engine. When I turned the key, I thought someone was shooting at me. Horrible machine gun sound that you hear in the movies, and it won't start up.
Measured the battery, while disconnected, showed 10.4V. It was Super Start Premium 72 month battery, which is 4.5 years old. So, I replaced the battery, and now it cranks up no problem.
I had dead batteries before on this truck and various other vehicles I've had, but never had these behaviors.
It just past 105K miles, I think it's time for its first tune up.
Old Aug 11, 2014 | 07:07 PM
So did the lock issue resolve itself after the battery was replaced too?
Old Aug 11, 2014 | 09:31 PM
jbrew's Avatar
That's what happens, just before the battery kicks the bucket - they take the truck to an interdenominational gateway, via time-warp before totally kicking the bucket. You were lucky, you just "heard" machine guns...did you see any landscape changes?
Old Aug 11, 2014 | 09:45 PM
greenmeanh1's Avatar
Once a battery falls below 11 volts it pretty much a dead battery causing chattery starters and computer brownouts. Battery probebly just bled down while sitting for a few days.
Old Aug 11, 2014 | 10:47 PM
jbrew's Avatar
I think it's a 11.6 volts minimum if I recall correctly.
Old Aug 12, 2014 | 07:54 AM
jaymz's Avatar
GEM module?
Old Aug 12, 2014 | 11:33 AM
Tasca Ford Parts's Avatar
Former Sponsor
With the way everything is controlled by computer modules these days it can cause bizarre behavior when there are voltage issues.
-Steve
Old Aug 12, 2014 | 07:02 PM
2002 wonderboy's Avatar
I instantly thought of the truck in Buckaroo Banzai
Old Aug 16, 2014 | 07:54 AM
jbrew's Avatar
That looks like something from Mad Max. Nahh, too new.
