Two or three bolt Starter????
Old Jun 8, 2014 | 01:13 PM
jaymz's Avatar
Need to replace the starter on my 1997 XLT 4.6l 4X4.
Some of the starters I'm seeing are 2 bolt attachment and some are three bolt. How do you know which to order???
Please help; don't want to crawl under there again!
Old Jun 8, 2014 | 04:59 PM
jaymz's Avatar
No One?
Old Jun 8, 2014 | 09:34 PM
4x4wolf's Avatar
Don't know about 4.6 but my 5.4 is three bolts. Not sure if it will help but I know there very similar motors.
Old Jun 9, 2014 | 07:37 AM
projectSHO89's Avatar
I've never seen a Ford modular engine with a two bolt starter.
Old Jun 9, 2014 | 09:20 AM
jaymz's Avatar
Turned out to be a three-bolt. Got the lower two bolts out, but that third one is going to be a bitch. I can feel it, but can't see it. Seen the videos of going in from the wheel well, but still looks like a PITA. Anyone else got a trick to remove it?
Old Jun 9, 2014 | 04:34 PM
4x4wolf's Avatar
Multiple wobble extensions
Old Jun 9, 2014 | 09:12 PM
Wheel well or by touch only. Your choice.
Old Jun 14, 2014 | 10:02 AM
jbrew's Avatar
By touch here. As long as you have the correct extension on hand, it's fairly easy.... IMO.
Old Jun 14, 2014 | 10:04 AM
jaymz's Avatar
Went in thru wheel well; wasn't too bad to remove that way; 13mm socket/u-joint/12" of extensions/ratchet with handle that turns when you don't have enough room to swing it (boy, am I glad I bought this a few years back).
