View Full Version : 1997 - 2003 F-150
- 98 F150 4.2 possible blown head gasket
- Mushy Brakes?
- New mod for 150
- Shutter after engines warm
- Making the right choice f-150 2002
- Electrical problems..Ignition?
- Vehicle won't crank
- No 4x4, vacuum through only one solonoid
- 2002 f150 tranny and axle suggestions
- No start AFTER new fuel pump, now no spark
- Broken shift fork?
- 2000 F-150Headlight replacement Help
- Painting 16 Aluminum Alloy Rims and Center Caps
- Popular Mechanics review Circa1999
- ''98 Powerdyne SC head upgrade time, Help
- 2000 F150 Leaky Windshield
- 1999 F150 Only taking 1 1/2 gals coolant
- Braking problems
- 4r70w transmissions problems
- code p0720
- Got a new (to me) screw
- '03 King Ranch 2X upgrades
- Rims and Tires 97 F150
- ignition issues
- oil leak
- bench seat to 40/60 split seat.
- My heater core just blew!
- 2001 f150 XL 4.2L water pump replacement
- Hellwig Sway Bar
- Built vs Bought
- Fabtech & RCD Backspacing?
- F150 speedo pegged (over 100mph) at idle.....
- AC Delco Coils Review
- 99 F150 4wd weird, engages all ranges when turning key first time after battery reset
- Camo covered dash bezel?
- GEM module Questions
- Drivers Window will not go down, relay clicks 2002 f150
- 1998 f150 speedometer not working
- Abs code c1194 2003 lariat help!!!!!!
- 1997 Ford F150 bucking or jerking while driving
- How to remove back panels on a 1998 Ford F-150
- heat problem
- 2000 F150 Radio & Wipers troubles
- 2000 f150 v6
- Hey Guy's new to forum
- 10.25 373 LSD Rear End - Which Fluid and How Much?
- ford f150 1999 4.2 no power in fuel pump
- Coolant Leak
- Decent shops in spring area?
- 98 ford F150 4.6 missing
- Kill it with Fire
- Leaving the club soon
- Is this stock on a 2003 f-150 4x4?
- 1997 cougar 4.6 work in 1997 f150
- 99 f150 5.4 fuel injectors
- 2001 F-150 7700 Questions about History
- Truck update
- Anyone have issues after going to Synthetic oil?
- CIPA Custom (Slide-On) Towing Mirror Modification ?
- 2002 Supercrew
- Error Codes
- 1999 F-150 4x4 wheel studs
- 99 4.2 Tapping
- Steering wheel off center
- Need 98 F150 2WD GEM Module
- Code of Ford ID-Sticker
- Brush Guard Question
- plans on build of my 2000 xlt
- Clunk when shifting into 4WD (high)
- Stowable Bed Extender
- Cab Braces
- Different front end camber settings?
- 2001 f150 front end noise
- 4r70w can i swap it with a 4r100?
- Need new multifunction switch?
- About to purchase
- Raw gas smell at startup
- new to forum and site ..
- 200000 miles
- Which lift kit?
- Damp Passenger Footwell
- New COP's and plugs now runs great but.....
- Late Model Running Boards on my '99 Scab?
- Misfire again?
- Need info
- new intake
- Vacuum leak
- P0171/174 At my wit's end
- Homemade differential drop
- 4.6 to 5.4 Conversion Tuning
- I guess I have the V10 bug
- blinking theft light
- Heater Core Replacement Ruined My Truck
- 98 f150 heat
- 2002 King ranch
- My 2003 died protecting us today
- 4x4 esof problem, already replaced GEM
- Starting issue
- Ac problem
- F150 7700 cracked rear axle
- Driveshaft
- Confused about F-150 radiators
- Truck won't warm up
- good websites for parts?
- Wheel suggestions for '01 F150
- m5od issues and fixes.
- Composite intake manifold cracking
- Seat Belt Retractors
- Home link Garage Opener
- Bigger tires
- New guy introduction
- How do I use Starter Fluid? 1999 F-150
- Best Oil for High Mileage
- Need Electrical Help! I shorted all tail lights and more...
- need help
- 2001 trouble shifting out of 4WD
- 2003 ford f150
- Plase help! running on 4 cylinders.
- Cruise control disengageing
- 2001 4x4 Front Axles Slipping?
- F150 Lariat Super crew cab heating blowing cold air
- Gunpowder smell
- 2000 f150
- Looking at 2002 Scab 4.6L, What to Watch out for
- Engine Noise/Possible Lifter Tick
- NEED HELP!!! 4r100 swap
- 4.6 wires or not?
- '00 F50 type & size gas tank vent hose
- 99 f150 5.4 engin shudder - MERGED
- 99 4.2 Cel
- Block heater humming 2000 4.6l
- Clipped the Light Pole
- What is my Truck Worth - Need an Honest Valuation
- Tires and Rims
- Please help! 1999 Electrical issues.
- BORA Spacers For Rear Wheels Only
- 4" Suspension w/ 35s, who is running it, advice?
- Bought it yesterday. My first f150.
- Wisps of smoke from the inside air vents
- popping and clicking
- Rear slider leaking...again...
- How to: tow mirrors 97-03 supercrew f-150
- 1997-2004 Ford F150 4X4 Inoperative In Depth Diagnosis
- Coolant level dropping
- Engine swap info needed!
- How long can she sit?
- Boss 5.4 Side Skirts
- 2008 4.6 into a 1997 f150?
- Rim and Tire Help
- Plastic peices found under t-stat
- Lighting Tb to normal 5.4
- PIAA valance/airdam
- Injector causing misifre on cylinder #6
- 2003/04 ford f150 4.6l Odo reading (------) theft sequence 1:6 help
- We replaced a head gasket and everything is hooked up right
- Spark plug blown (pushed) out
- 2003 f150 7700 possible upgrades
- can't get more than 1/2" from torsion crank
- power feeds
- Pressure: 265/75R16 E's on 99 F150
- offset
- Mb tko
- Temperature too Cold??
- Fuel gauge is off
- Possible bad cv axel?
- A moan-free, '03
- more comfortable jump seat?
- my before and after!
- New buyer's thread or sticky
- intermittent start problems when the truck is hot
- cruies control
- New Fuel Tank: Tank Straps To Short
- THROWBACK VIDEO F-150 Soars in the Air
- Overdrive light flashing
- High mile spark plug change
- Cost of head gasket
- I bought a plug spitter
- Lariat Script and stripe decals?
- Heater core replacement
- Lower Control Arm Bushing Replacement...Help Please
- o2
- 5.4 swap and torque conveter problems
- 2002 F150 ignition stays on and starting problems
- 97-99 Cornering lights
- New plugs, Newb mechanic needs help
- transmissions help plz
- whos got headers?
- Rumbling and no power when shifting gears
- Cleaning the engine
- compatible bench seat for 2001 F-150 standard cab
- Preparing for spark plug change on 2001 F150 V4.6
- Led light bar
- Alarm has a mind of it's own
- How to tell what size gas tank?
- Interior light override switch help!!
- HID problem??
- Doors Unlock but Won't Lock
- 4.6 engine dress up
- Cylinder 8 misfire
- strange object underneath
- leaking coolant from housing unit
- Battery and alternator test good but voltmeter is staying low.
- Door Removal?
- Wits End Stalling
- lightning badges
- I want to level my 1998 Ford F150 xlt
- lightning badges
- 2003 cowl hood
- Gear Oil?
- Need wheel information
- Transmission Fluid level
- Need advice
- New guy. Possible new buy.
- 99 F150 Efan upgrade
- High idle after cleaning Throttle Body
- Interior Parts
- 99 F-150 4.2 harmonic balancer timing
- Are the coil springs for a 2003 f150 really unavailable?
- 99 f150 xlt no guages no windows
- 99 F150 4.2 top dead center
- Show me some carpeted floor mats!
- Probably should have posted before pulling the trigger on suspension lift kit
- 1997 Ford F150 V6 4.2L Stuck in park
- Front Hub Replacement
- Changing interior lights
- 126,000 oil?
- Weird clicking when slowing down and stopping
- Heat & Air Problem
- Nitto Terra Grappler 295 70 17 or 305 70 17?
- rims
- 1997 gauges going crazy
- 100,000 Tune up
- Bench Seat Specs
- temp gauge
- Obtaining service manuals
- 2001 F-150 won't start -- question about fuel system
- 98 F150 SupCab 2WD No Speedometer, No Trans Shift
- Door Panel Bulb number needed!!
- door locks
- Power Steering pump.
- 2003 4x4 Grinding Noise
- 1997 Ford F150 AC Compressor advice
- 2003 fx4 with 250,000 miles worth buying
- compass and temp guage
- L.E.D dash lights
- keypad entry on an xlt?
- Rims + Tires
- Engine part cracks everywhere
- 02 f150 5.4 4x4 help!!!
- 2003 F-150 Strange Problem
