4r70w can i swap it with a 4r100?
Yes, it will fit under the truck because the E4OD/4R100 was an option on the 97-03 F-150.
Look for member "ishootstuff" s thread on his V-10 swap. Good luck. Member "camdenlake" also did a V-10 swap and has a thread.
Mixed feelings about how it turned out? The only thing that doesn't work like factory is the cruise control. What is mixing your feelings?
On running the dual computer set up. But I would like to get with you on how you did your motor mounts. If you could email me at waterblaster08@gmail.com that would be GREAT
