View Full Version : 1997 - 2003 F-150
- OBX Long Tube Headers for 98?
- truck got a boo boo
- ahun98's transformation thread
- Have an opportunity to pick up straight spoke OEM rims for $100
- Looking for Opinions
- 98 f150 cluster swap to led bulbs
- 2000 Ford F150 4.2L 6 cyl. NO HEAT
- going to look at a used tranny....
- Spark Plug Problem! Need diagnosis please
- Torsion bar help!!
- 2001 4.6 liter with 285's and 3.31's?
- 7700 questions
- Will a '07 Navigator steering wheel fit a '03 Lightning?
- Both Low Beams out. Replaced bulbs and MFS, didn't help
- Help lift my truck!!
- PTM Lower valance 2002 4WD!!!
- 2001 4.6L issues
- 2000 valve train noise
- Location of radiator cap for 2000 Ford f150
- Coolant smell from vents
- Abs and E-brake Lights came ON again
- 2001 f-150 wont start
- Lets talk front gear install
- 1999 F150 4.2L Whistling Noise
- ac
- Please help!!!!
- Fuel Smell
- Stupid Buzzard's Need a replacement Mirror
- Did the dealer screw me??
- 97 f150 bagged, build thread
- Just finished installing
- Brake Pressure Switch-Cruise Control
- 97 4.6 - Head Gaskets.....what else?
- Help Installing grill Guard
- weird problem with ac vents
- 03 fx4 suer crew vibrating
- Fuel economy?
- Before and After
- torsion bar help
- Help!
- 97 Ford F150 4.6 litre
- Window Stuck Down Help
- Pulling Carpet out on a 2000 F-150
- cutting off cats
- P0302 Cylinder Misfire - Fixed
- Calling All Dads...Help me show up my son
- 13 miles to the gallon
- Truck won't idle
- need opinions please!
- My new/used tires!!
- E3 Spark plugs
- Best Foglight Setup for 1997 F-150 XL
- Superduty !@#$%^& conversion
- Instrument cluster/head unit
- Over-cab lights?
- Realy loud intake
- 5.4 Oil Filter Change: How to avoid making a mess?
- 3'' body lift?
- Air Conditioner Drain
- About done installing Roll Bar
- super charger anyone? craigslist
- New Deck
- Ignition Coils
- fluid issue
- Fuel pump going bad???
- Which spark plugs?
- 2003 4x4 will not disengege
- good system cleaner?
- where to get some black and crome wheels 03 f150?
- seats
- Engine swap?
- Which 4.6 motors will go right in a 97 ??? Please Help Looking For Motor
- upper control arm balljoints
- old faithful still faithful
- ahun98's 98 to 99+ bumper conversion
- power steering leak
- Should I Lose the Bug Deflector?
- What I have done to my truck...
- Valve Noise
- Got it lifted
- 285 70 17 Nitto TG on stock rim
- About to lift my truck ;D
- new here hi evrybody
- How much horsepower and torqu do you think I have?
- Power balance test
- Has anybody had this happen?
- To paint or not to paint?
- Project Roll Bar
- Intermittent Misfire Cylinder 4
- Added 6" Off Road lights and Painted the Grill black.
- ABS light coming on
- Any experience with eBay pads/rotors?
- May need tuning for cams?
- drl output wire 98 f150
- Time to do some work!
- Replacing heater core. Which one to go with?
- Some warning lights on instrument panel are out.
- Drivers side power window problem
- 2003 Ford F-150 Noise!!! HELP!
- Couple pics
- rebuilt my Efan setup
- Bosch Iridium plugs
- A/C Stopped working
- No heat or a/c help im new here
- Does my truck have a cabin filter?
- Help with SpringTech Lift Spindle. No holes for dust cover bolts?
- Just installed my 6+3 and 20" Rockstar/Toyo combo!
- High NOx emissions
- Look what was waiting for me after my deployment!!!
- Power door Locks and Cruise Control???
- Can a dirty throttle body effect the IAC?
- leafs
- Clutch Problems
- New Paint Job Question?
- Need dimensions for rear cab wall carpet
- Back-up Camera Placement
- I built my own front mount hitch to mount my new winch (PICS)
- Need help decoding interior color
- Cleaning throttle body question?
- rear diff weeping
- 97 f150 top ten most stolen in 2010
- 5.4 feels like 2.0 ..please help!
- 5.4 problem 9/11/2011
- Starter help
- 2003 F150 4.6l starting żIAC issue?
- 98 to 99+ bumper conversion
- got a few issues
- pretty fast help required here please
- CB antenna Advice
- new member
- wheel base
- Antifreeze Leakage?
- white flat wire harness under steering wheel
- Black out none black F150 :D
- Windshield Wipers Part Time
- I want more height!!!!
- Q - Repair manual
- Mounting Amps in Space Behind Seats?
- Heater Core
- 02 4.6 supercharging
- 7 pin connector "BRACKET"
- Recycled ECU. Will I Pass Emissions?
- 4.6 starter on 5.4?
- Anyone using hi-lift jacks?
- Efan wiring- A/C & ignition help
- 98 F150 4.6 Blown Head Gasket or Intake Manifold
- double din in 97-98
- changing bulb in mirror blinker ('03)
- clunk in front bakes
- Brake pedal drops
- Stop it please! (Need brake advice)
- LONG weekend of mods!! (lots O pics!)
- Need help with engine!
- Issue with Loss of Power Under Load
- rotten egg smell, vent only, bad gas mileage
- Radio, windows, starter without ignition switch
- Gryphon CS?
- istalling fog lights on 01?
- water injection
- No Start
- 12-volt accessory cover spring
- Moon roof help please
- What lug nuts do I need with my Rockstars?
- M5OD R2 Shifter Repair
- fit 35s?
- Fuel Tank Pressure Sensor wiring question
- Where is the best place to buy brake rotors?
- oil pressure gauge problem
- Would like information
- No CEL with constant misfire
- Sharing maintenance of ageing '97
- 1999 Programmable Ignition Key Instructions
- My truck sounds like a honda..
- Help!!!!!!!!!!!!!!
- Honey comb Grille
- Is my alternator going bad?
- Back to a F150 nice deal too
- where could i find this style 97-98 bumper?
- p1451 evap code
- CEL flashing, rough idle & power loss
- Info from the Owner's Manual & 2 Questions
- Idle Problems
- COP's & Plug replacement, what did it cost?
- Parking brake for 99 F150 4W Disk repair
- Codes p0171 and p0174
- Pillar Gauges suggestions
- My eyes!
- 4.6 to 5.4 Swap
- Scored A Sweet Deal!
- Master cylinder nut size different for cruise?
- DPFE Hoses (2 different sizes?)
- Well guys I think I found my lift kit!!
- New Ignition lock
- Backup sensors on an 03?
- Minimum lift needed??
- What a DAY, what a DAY... thats all i can say..
- sporadic no-start - what should I look for?
- Fuel Smell??
- Max Tire Size?
- Somebody messed with my truck!!!
- Ruby's Transformation Thread
- speed gauge
- Worth doing a lift at higher miles?
- Hope my wife and 2002 FX4 screw makes it through Irene!
- 2009 and up 9.75 rear locking diff in a 2002 9.75 housing?
- Engine sputter. Need help!!
- mods for better MPG, towing?
- Acidently filled 4R70w with Mercon then drained & filled with Mercon V. I need input.
- Rattle during cold start up
- A little help requested for some trouble codes
- ABS light came on and loud humming under hood
- Need Help NOW!!!
- dash help please
- Replaced steering wheel and clock spring, now creaking/rubbing noise when sharp turn
- supercharging stock 5.4
- Check Engine after getting gas
- New mods and paint!
- Steering column bearing
- Theoretical Engine Swap.
- Won't turn over after working perfectly yesterday???
- Odometer Fixed, now new beeping noise?
- Perimeter grille
- Inquiring about replacing both front and rear u joints for driveshaft
- Door Molding
- 2002 Instrument Cluster Bulb number? Not 194
- How to FIX Chime that won't stop dinging when key is out.
- Newer Running Boards on our style?
- how to tell if you have automatic door locks
- Want to lift a 2wd f150
- Change or not to change transmission fluid
- Drivers window motor issue
- 2003 F150 AC issues!
- Crazy waterloss please help ('98 5.4 4x4)
- Need seats for your older F150?
- 8 Lug Hubs Rotor swap ?
- 1998 f150 4x4 xlt I need HELP
- Canned vs Custom tunes.
- Speedometer Probs Help
- New addition to the family---> The Wicked Project
- gas tank
- Lift Spindle 01 F150 Rwd Install question
- 2003 f-150
- 99 F-150 V8 starting problems
- 265/35r22s on a 22x10in rim
- walmart supertec synthetic
- fuel
- Biggest Tire 3.08 01 F150 4.6 Regaular Cab Rwd
- Wheel Spacers?
- Interior Color
- 99 4.2l new exhaust catback duals ideas??
