oil pressure gauge problem
Old Sep 2, 2011 | 01:23 PM
NickArellano97's Avatar
Unhappy oil pressure gauge problem
when I break going more than 50 mph the oil pressure moves. Its never done this. Ive only gone 1 month over without changing the oil. This just started today. http://www.youtube.com/watch?v=U1egI...er_profilepage
Old Sep 2, 2011 | 02:08 PM
Stupid question - have you checked the oil level?
Old Sep 2, 2011 | 03:12 PM
duh! oil is fine.
Old Sep 2, 2011 | 05:25 PM
Just checking!
You may have a plugged pickup screen, or maybe the sending unit is starting to go.
Old Sep 2, 2011 | 05:30 PM
maybe. were r those located? how easy to replace
Old Sep 2, 2011 | 05:55 PM
The sending unit is right next to the oil filter, and is pretty easy to change. The pickup screen requires oil pan removal, and THAT is a pain.
Old Sep 2, 2011 | 06:27 PM
ok so maybe it is the sending unit because I took of the oil pan before and cleaned everything in there that i could and sealed it good. and havent messed with the sending unit at all.
Old Sep 3, 2011 | 01:39 AM
all rite its now fixed. I took off the sending unit cleaned it and around where it mounts and retightened it. and checked the oil level again three hours later and it went down to the add Line. I bought new oil and filter so i changed it. now its working fine. glad it worked. thanks glc
Old Sep 3, 2011 | 01:59 AM
Buxton91's Avatar
If it starts to act up again, just replace the sending unit. I had to replace mine again this week. It's only like a $10 part.
Old Sep 3, 2011 | 02:08 AM
cool.
