Minimum lift needed??
Old Aug 28, 2011 | 07:30 PM
Smitha6's Avatar
Question Minimum lift needed??
I have a stock 2003 King Ranch Super Crew and I want to put 35's with no bigger than 20" wheels on it eventually and i'm wondering what is the minimum amount of lift or whatever I will need to do so? I dont want a huge lift, i want the wheels/tires to not scrub but also fill the wheel well.
I also have the towing package, if that makes any differance?
Would just a leveling kit work, getting the nose up even with the rear?
Thanks!!
Old Aug 28, 2011 | 07:34 PM
USAFORD's Avatar
You dont have coils in the front therefore you cant get a 'leveling' kit. you have Tbars, so you can crank them to get a few unches of lift in the front
Old Aug 28, 2011 | 07:44 PM
Smitha6's Avatar
Does that mess with the handling/ride or anything?
What are the advantages/disadvantages of this?
Old Aug 28, 2011 | 08:00 PM
jdt_ellinor's Avatar
whoops didnt even look to see if he was 2wd or 2wd just assumed.
Old Aug 28, 2011 | 08:08 PM
joh408's Avatar
Since your 2wd you will need at least 6" of lift for 35s and you do have coils
Old Aug 28, 2011 | 08:47 PM
DMNSPD's Avatar
It looks like your truck is 4wd since you have fog lights on the front. If it is 4wd then you simply need to crank the torsion bars in the front so that they raise up the front end approx. 2". This may stiffen the feeling of the front suspension and you will need to get the front alignment redone. Once you have done this you can mount the 35" tires and will have to trim the corners of your lower valence just slightly so that the tires don't catch as you move the steering wheel.
I run a set of 315/70R17 BF Goodrich A/T on my 2003 with zero rubbing on a set of MB 72 wheels that measure out at 17"x8.5".
Old Aug 29, 2011 | 09:14 AM
Smitha6's Avatar
I have 2wd
Old Aug 29, 2011 | 09:58 AM
GATOR CREW's Avatar
2009 F150online Truck of the Year
For 2wd, I would go with a 7.5" Fabtech , that was my set up when I ran 35's and had no issues! I now have a 3" body and a 1.5" coil spacer in the front running 37's
Old Aug 29, 2011 | 10:27 AM
pizzaman711's Avatar
2wd either go 7.5 fabtech or the 6.5 springtech.
Old Aug 29, 2011 | 11:53 AM
Smitha6's Avatar
7.5 seems a little much, 6.5...ehh, 6 maybe...i want the absolute bare minimum to have the tires clear and not rub without modification to the truck except the lift.
I'm never going to put anything bigger than 35's, i'm never taking it serious...or maybe even at all...off roading so i dont need some super heavy duty one for that.
Basically, I just want the tires to fit and thats it.
Old Aug 29, 2011 | 12:35 PM
6" will rub with 35's. 6.5" is the bare minimum basically to clear with no rubbing and maybe minor trimming. 7.5" fabtech will clear perfectly and set you the same height as a 4x4. Don't forget wheel's make a difference too, go with something 8" wide with about 4.5" of backspacing.
Old Aug 29, 2011 | 01:09 PM
Smitha6's Avatar
A 4x4 sits that much higher than a 2wd??
Yeah...i'm not real up on spacing and all that...all i know is i like the "suqare" looking tires...if that makes sense?
Old Aug 29, 2011 | 01:26 PM
A stock 4x4 is generally 1-2" higher than a 2wd, sorry I meant it'll sit as high as a 4x4 on 6". I'm not sure what you mean by square tires though. But you can look through my album to see what a truck on 6.5 inches looks like with 35's.
Old Aug 29, 2011 | 02:55 PM
Buxton91's Avatar
If your gonna be running 10" wide wheels or tires wider than 12.50 you might want to consider the fabtech 7.5". It sounds like a huge lift, but with 35's on there it fits perfect. With just the springtech kit you might run into some rubbing issues if you don't find the right wheel and tire combo.
Old Aug 30, 2011 | 09:14 PM
Smitha6's Avatar
Wanna add as well...My truck will rarely if ever go off road...so would that allow for a smaller lift since I wont have to worry too much about travel and everything? Or does it matter?
