Fuel Smell
Old Oct 6, 2011 | 04:09 PM
Dee Burton's Avatar
Fuel Smell
I just changed my spark plugs and air filter now my truck smells of gas from the engine and exhaust.
Old Oct 6, 2011 | 04:20 PM
Did you tighten the spark plugs to 28ft/lbs of torque?
Old Oct 6, 2011 | 04:22 PM
^^^^ A must
Old Oct 6, 2011 | 08:19 PM
paker's Avatar
Is 28 ft-lbs for all engines of F150? If so, source?
Old Oct 6, 2011 | 08:34 PM
No......
Source? that's a first.....www.blownoutsparkplug.com
jbrew or glc will back it up also.....
Old Oct 6, 2011 | 09:46 PM
Bluegrass's Avatar
Did you do anything with the fuel rails or injectors?
Old Oct 7, 2011 | 07:02 AM
jbrew's Avatar
Exactly what I was thinking. It was bumped and one of the o-rings lost it's seal.
Or, -reinstalled incorrectly.
Also the rail connections use a spring clamp that rusts out over time. My rail became disconnected @ about 55 mph. Pumped fuel all over the back of the motor and immediately shorted #8 coil. Make sure your spring connector at the rail is fully intact. I was lucky I didn't get blowed up. I made it back to the house using my boot laces to temporarily re-secure the line in place. Just in case it happens to you, in the middle of nowhere.
Old Oct 7, 2011 | 10:48 PM
paker's Avatar
Originally Posted by jbrew
....... boot laces to temporarily re-secure the line in place........
A very useful tip indeed. Thanks. Fuel pressure is about 40 psi. Isn't transmission line about the same pressure?
How do you explain fuel smell in exhaust?
