clunk in front bakes
Old Sep 6, 2011 | 03:29 PM
bubba1's Avatar
Hi guys, I just did front pads and rotors on 1998 F-150 supercab 4x4, the truck stops smooth and straight, but when you backup you get a clunk, and when you put it back in drive and stop you get another clunk, and it will be fine for forward braking until you backup and stop, then it repeats back and forth. anybody know what i should be looking for? I greased the slides and put brake quiet on back of the pads and washed all the parts with brake kleen when i was done. Thanks for any help.
Old Sep 6, 2011 | 04:11 PM
jethat's Avatar
Check the u-joints and have you looked at your e-brake lately? you have to remove the rear caliper and rotar to look at it..
Old Sep 6, 2011 | 04:55 PM
Exactly where does the clunk sound like it's coming from?
Old Sep 6, 2011 | 04:59 PM
bubba1's Avatar
the clunk is coming from the front wheel you can feel it in the brake pedel.
Old Sep 6, 2011 | 05:35 PM
Are you sure you put everything back in - like shims and clips? It's usually a good idea to put a new hardware kit in when you do disc brakes. Something is loose that shouldn't be.
Old Sep 6, 2011 | 05:43 PM
bubba1's Avatar
they are the original clips but they are in good shape and the pads seemed to be tight when i put them in, it does not have shims. i would go out and check the bolts to make sure there tight, but its raining over here on the east coast. ( no garage )
Old Sep 7, 2011 | 01:02 PM
Raptor05121's Avatar
check the ball joints. mine are gone and make the front brakes do exactly what you're saying
Old Sep 7, 2011 | 02:24 PM
bubba1's Avatar
The ball joints were good before the brake job, but i had to hit the rotor with a 5 lb hammer a couple of hundred times before it came loose. do you think the vibration of hitting the rotor could have made the ball joint loose?
Old Sep 7, 2011 | 02:25 PM
BLUE20004X4's Avatar
Check tie rods too! While you're at it anyways.
Old Sep 7, 2011 | 02:28 PM
bubba1's Avatar
I checked the tie rods when it was up on the jack, they were tight.
Old Sep 8, 2011 | 04:19 PM
01 gt f150's Avatar
I can't remember the name of the damn thing but I had bolts come loose on the caliber mounting bracket. I believe they were 19mm. Everytime I hit a bump you could here a clack sound. Check those just for GP
Old Sep 8, 2011 | 04:27 PM
jethat's Avatar
Get the front disc hardware kit at autozone and pull the calipers and install it. Less then $10
Old Sep 9, 2011 | 11:48 AM
bubba1's Avatar
Hi every one! UPDATE ON CLUNKING NOISE IN FRONT BRAKES. well it stop raining and i jacked up the truck and took off the wheel and the two 18mm caliper bracket mounting bolts were a tad loose, i tightened the bolts about 1/8 of an inch and "Bingo" the noise went away. you would be surprised the it made so much noise just from 1/8 inch. I want to thank every one for all your help. Thanks BOB
Old Sep 9, 2011 | 02:25 PM
01 gt f150's Avatar
Sweeet!!!
