Window Stuck Down Help
Old Oct 2, 2011 | 06:46 PM
2000F1504.6's Avatar
My passenger Window is stuck down on my 2000 F-150 XLT SuperCab. The motor went out on it and i need to prop it up before i drive to school please help!
Old Oct 3, 2011 | 12:14 AM
Bluegrass's Avatar
You really don't know what it is at this point.
My bet is a switch.
Here is what you could do.
Take the door panel off.
Find the two wire cable plug that is exposed to see.
Seperate the plug and apply battery to the window motor in the up polarity and try to get it to go closed.
Then try to get a switch from a yard to replace yours or the whole top switch assembly.
Be carefull to match up with your original because they all look much the same on top but big differences per model and year. Been there already.
Good luck.
Old Oct 3, 2011 | 08:47 AM
kernelpanic's Avatar
that's what happens when you cut out the cats and disable the O2 sensors
