fluid issue
Old Sep 27, 2011 | 04:07 PM
1slosvt's Avatar
fluid issue
i have 98 f150 4wd ext cab 4.6 auto. at about the same place where your ac drips i have a fluid thats kind of brownish in color(hard to verify color since its on the ground) coming out without ac running since its 60 degrees here. i cant see exactly where its coming from as theres to much in the way that its running off of. from what ive researched on here i think its the heater core but have zero fluid inside. does any one have any ideas before i go through the giant task of pulling my dash to replace the core. any help or info would be greatly appreciated
Old Sep 27, 2011 | 04:17 PM
Need4racin's Avatar
if it's leaking from the actual ac lines it might be compressor oil leaking out. If that leaks out your compressor will seize up.
Old Sep 27, 2011 | 04:50 PM
Have you checked the coolant level to see if it's losing any?
The A/C is running if you have the switch in anything except PANEL or FLOOR (or OFF - duh )
Old Sep 27, 2011 | 05:03 PM
1slosvt's Avatar
yes the coolant level is definitely dropping. i dumped a gallon in the overflow the other day and it emptied quite quickly so it was definitely low
Old Sep 27, 2011 | 08:31 PM
jbrew's Avatar
Not the core, you would smell it inside the cab and the floor would be wet.
Shine a flashlight behind the alternator on top of the block valley. Are you holding coolant in the cavity ?
