Cleaning throttle body question?
Old Sep 12, 2011 | 06:08 PM
sniknah's Avatar
My truck is a 2001 5.4L with 86k miles, I'm thinking of cleaning the throttle body...how difficult is this? Would you reccomend doing it at 86k? Do you notice any difference by doing it? Appreciate any input or threads on "How to" Thank you!
Old Sep 12, 2011 | 06:47 PM
jethat's Avatar
When I did mine at 100 k it made the truck noticeably run better. Its not that hard. I plan on doing mine more often now. If you really take your time and scrub it good it takes 2-3 hours. I imagine it could be done in an hour.
Old Sep 12, 2011 | 10:08 PM
sniknah's Avatar
Why does cleaning it help with performance? anyone know? Any other parts I should replace while doing this?
Old Sep 12, 2011 | 11:11 PM
str8t six's Avatar
clean the EGR valve and ports.
Old Sep 14, 2011 | 12:10 AM
rch10007's Avatar
Fluid dynamics.
Old Sep 14, 2011 | 12:28 PM
Raptor05121's Avatar
Wow, what all are you cleaning? It usually takes me 15 min tops to clean mine
Old Sep 14, 2011 | 12:37 PM
This is in the Articles and How To section, in the index:
https://www.f150online.com/forums/ar...ttle-body.html
Be sure and use a tooth brush or similar brush to clean the hinges of the butterfly.
Old Sep 14, 2011 | 12:46 PM
robiford03's Avatar
its pretty easy did it to mine and you feel the difference somewhat
Old Sep 14, 2011 | 12:48 PM
If you don't clean it, it can get so dirty that the engine dies and goes into failsafe mode.
Old Sep 14, 2011 | 02:50 PM
Failsafe is only on the 04+ with electronic throttles.
Old Sep 14, 2011 | 03:01 PM
Sure, I should have remembered that. Thanks
