CB antenna Advice
I don't know what you are hearing or reading that would indicate an advantage to the move.
Basicly an antenna mounted on one side has it's radiation pattern determined by the cab and frame shape.
Moving it to the oppsite side only reverses the pattern with no advantage.
A better place is in the center of the cab where the pattern will be more elongated fore and aft the truck instead of being distorted to the side.
Good luck.
Good luck.
You get longer ranges to the side away from the antenna due to how a ground plane works. Example - to get the longest range to the front and left of the truck, mount it on the right rear side. Who do you want to talk to? If you want to talk primarily to people in front of you on the other side of the road, that's where you would put it.
so your saying instead of putting it on the driver (what it is now) and then put on passenger and ill get longer range with it
No. Read my post again.
If you want a symmetric range, put it square in the middle of the truck. Any offset from that - be it side to side or front to back - will change the directionality of the antenna. In which exact direction do you want the longest range?
okay thanks. also how much extra range will i get with it like that, and will i need to change whips cause im thinking of mounting it on the center of my tool box like str8 six (my whip is a 4' firestick)
Thanks for all your help
