Some warning lights on instrument panel are out.
Old Sep 16, 2011 | 10:57 PM
paker's Avatar
According to the manual, I am supposed to have the following lights lit with key @on,
Low fuel
Oil pressure
Coolant temperature
Door ajar (if door open)
Charging
Brake
Seat belt
Air bar readiness
Check engine
ABS
I don't get door ajar, seat belt, check engine on my 97. Should I expect a major repair or a simple light bulb replacement? Thanks.
EDIT: There is no error code on the scanner.
Last edited by paker; Sep 16, 2011 at 10:57 PM. Reason: PS: No error code on scanner.
Old Sep 17, 2011 | 12:52 AM
pizzaman711's Avatar
Just a bulb replacement, or maybe more than one ha. Not too bad of a job, but now's the perfect time if you wanna change the cluster lights.
https://www.f150online.com/forums/ar...r-97-03-a.html
That's a how to so you'll know how to get to them.
Old Sep 17, 2011 | 09:53 PM
paker's Avatar
Thanks for the link. Bulbs were missing/burnt out. All good now.
For My Own Record: Bulb # 37, 73, 74 for warning lights. 12V 1W
