PDA
View Full Version : 1997 - 2003 F-150
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. '02 5 1/2' bed hard covers?
  2. 2001 F150 no crank issues HELP PLEASE !!!!
  3. Noise While Accelerating
  4. Fan Speed, Air Temp, Selection lighting Question
  5. stink from a/c finally gone
  6. 98 F150 cutting out at 35 mph to 45 mph
  7. Harley Davidson Gauge Cluster
  8. Pressure feedback sensor: Advice
  9. pain in the ass
  10. 2004 f150 heritage
  11. Plasti Dip
  12. Shoul i worry? EGR valve gasket fell into intake
  13. Shopping for OEM 5-spokes (opinions needed)
  14. New to me F-150...Wanna Make Some Mods
  15. styleside vs flareside bed
  16. Question
  17. Valve cover screw sizing???
  18. 98 f150 wheel spacers?
  19. 2001 King Ranch passenger mirror
  20. Rear Bumper on a Flareside
  21. Any Ideas?
  22. Need some honest input
  23. piston choice???????
  24. Normal or wore out? VIDEO
  25. Gauges need fixing
  26. supercrews with 33" tire picture
  27. dealer reflash
  28. fuel pump brand?
  29. Broken front axle housing x 2!
  30. IAC VALVE question
  31. F-150 Storage
  32. Changing oil?
  33. Brake fluid
  34. Fuel pressure low & leak down
  35. Unable to connect OBD - fuse 3 missing
  36. p1506 code after throttle body cleaning? 2002 F150
  37. Rear Shock Replacement - Cut them out?
  38. Recall notices?
  39. More poneys!
  40. How do i know if i have keyless entry?
  41. 2001 5.4 popping out of gear?
  42. 35 in tires
  43. wrecked rim on 1997
  44. Broken Front Axle Tube/Carrier
  45. 1998 towing
  46. high idle at start up? help
  47. 03 aftermarket shocks
  48. Rim Advise
  49. High mileage 03 SC / Towing a TT Reliability
  50. STFT B1/B2 S2 99.2%, is this normal? **PIC**
  51. need help with fuses
  52. 1999 F150 4x4
  53. Lift suggestions need help
  54. killed my transmission?
  55. Instrument Cluster won't light up anymore?
  56. clear courtesy lights?
  57. Starting Problem
  58. Replacing injectors at 100k miles?
  59. 2000 f150 power lock issue
  60. 97-03 f150 4x4 6in sus lift 3in body tire question
  61. New truck, few questions
  62. New tires/wheels and grille guard
  63. 03 F150 screw king ranch.
  64. interior lights
  65. what year 4.2 f150 engines are interchangeable with the year of 1997
  66. t bar suggestions
  67. Recommendations for COPs
  68. No Heat, Now Overheating At High Speed
  69. Broken Rear Brake caliper bolt
  70. Loud Front End Squeak
  71. New plans in action I'M back! LOL
  72. Motoring On: NFLD Flareside build thread
  73. grinding noise
  74. Looking for some help Lots of errors
  75. Belt Tensioner
  76. Fabtech Desert Prerunner bumper
  77. My screw needs tow mirrors
  78. 2002 F150 4.6- how do i know if my power steering pulley has gone bad?
  79. dome/interior light stays on but door ajar light is off
  80. 1997 f150 2 wheel drive shifting problems
  81. PCV elbow
  82. Engine Lift Bracket broke off
  83. Dead Truck- IAT sensor
  84. A Pillar Trim Help
  85. 03 Rear window surround applications
  86. 2002 Lariat SCrew shaking then bad mpg
  87. Loose O2 Sensors
  88. Had slight shimmy, balanced wheels, now its worse!!!!
  89. Parts no longer made
  90. 4x4 not working!!!
  91. fog light dead end :(
  92. Air flow shroud
  93. Steering wheel shake 02 f150 4x4
  94. 03 f150 rear view mirror
  95. 2002 Ford F150 - short in wiring
  96. 98 4.6 f150 swap for newer engine to be supercharged
  97. Help, my 2001 ranch died on the highway, towed home
  98. air bag code 52
  99. running rich!
  100. Help Me Keep My 2002 Lariat ....
  101. Truck bed size on 1997 f-150 XLT regular cab????
  102. codes p0171 and p0174
  103. Dead battery, new Alternator, short somewhere
  104. Possible Head Gasket
  105. Help with leveling kit
  106. PO171, PO174 and hard starting - fuel pressure reg?
  107. 4.6L Heads... Navigator?
  108. Turbo my 4.2 or swap in a 5.4?
  109. Broken ignition key cylinder
  110. Wet Floor
  111. Interior Paint Help
  112. Looking for an engine
  113. Transfer fluid n radiator reservoir
  114. No start fuel pump relay buzzing
  115. sold my truck
  116. Error codes P1121,P0133,P0121
  117. Roll over won't start
  118. heater fan only two speeds
  119. vibration 53 mph
  120. First Vehicle
  121. 3rd brake light leds
  122. Error code P0010
  123. chasing a high idle reason!!!
  124. repainting hood of 2003
  125. F150 Rear End
  126. pulling bedsides
  127. Part compatibility AC
  128. Severe miss
  129. Instrument cluster problem
  130. Found the cash, looking for power
  131. My 2003 SuperCrew 5.4L says thanks again..
  132. bleeding the brakes
  133. Need some new shocks, suggestions?
  134. oil leak
  135. Fog light problem
  136. Steering issues
  137. runs rough and dies at idel
  138. Guy wants all 8 Cyl's TIME-SERTed
  139. Fuel Gauge Doesn't Go Above E
  140. 97 4.6 loud squeal at start.....
  141. My Pretend Lightning (5.4 DOHC 4x4 Swap Thread)
  142. I'm lost
  143. Custom 97-98 F150
  144. Original Rancho Shocks 200000+ Miles
  145. 02 f150 5.4l 4x4 oil leak
  146. Need advice to lift or not
  147. Mirror Retaining Clips / Pins?
  148. rear shock help!!
  149. How does our front 4x4 work?
  150. 01 F150 blowing multiple fuses, Wont Start!!! Please Help!!
  151. Spindle lift?
  152. 1997 4.2 po302
  153. Greetings!
  154. Common Problem or Not? COPS #7-#8
  155. All Cleaned Up
  156. tire/wheel combo help
  157. just got my first truck and have some questions.. :)
  158. truck stutters when it gets to about 2000 rpms
  159. New Clutch and 285's Installed
  160. Sportin' Wood
  161. 2000 f150 4x4 4.6 liltre
  162. Door Jam Sticker? Can it be replaced?
  163. Door Jam Sticker? Can it be replaces?
  164. 2001 rear shock question
  165. May be a total noob question but...
  166. need help, running boards question!! Thank You
  167. How to protect spare from rusting out?
  168. rain leak??
  169. F-150 super crew cab, bed rail liner question
  170. seat covers for buckets w/armrest
  171. mystry elbow
  172. CA Emissions
  173. shes gone
  174. suspension help needed ASAP.
  175. Ford Power Steering Pump Teflon Seal Install
  176. Removing Front Grill ?
  177. Magnapack?
  178. 4wd actuator
  179. 98 xlt 4.6 no go
  180. Said Goodbye to the 7700 work truck ...
  181. Need Help With CD Player
  182. Timing Set! Is it right!?
  183. 2003 F150 Lariat EATC
  184. Power Accessory issues
  185. bench seat?
  186. 4.6L Severe stumble
  187. 33's Yes or No?
  188. Need advice for pulling a goose neck trailer
  189. 01 Supercrew Differential Rebuild
  190. Timing help!!! (2000 F150)
  191. Direction to take my truck in
  192. new motor is in. knock sensor plug??
  193. Running boards
  194. 2003 F150 FX4 with 100k
  195. Replaced everything, stumbles but no start!
  196. 98f150 reg cab child seat
  197. Parking Brake light Switch Location?
  198. 1999 f150 new wheel back spacing?
  199. Need advice on truck purchase
  200. New member needs some advice on a rough Nascar edition
  201. **Hidden Winch Help**
  202. start interlock switch?
  203. Shelby GT500 Engine on 97 F150
  204. Ford F150 2003 CRANKS BUT WON'T START
  205. 2002 F150 - is this close to real value?
  206. ET before the ECM reports mis fire?
  207. Heilcoil 1999 5.4 thorn in my side
  208. 03 f-150 fx4 lariat
  209. 2001 Rusted out Radiator support?
  210. inline 6 vs 5.4
  211. 2001 Transmission Oil Cooler Rattle
  212. 2001 front hub replacement
  213. Help replacing front right lug bolts (2000 f150)
  214. Removing throttle body help
  215. Looking for a definate answer
  216. No heat blow cold air
  217. Help with Part #
  218. 4x4 Suspension Upgrades
  219. fun things with the cubby hole below steering column
  220. Completely Dead
  221. Which years will work
  222. 2000 Ford F-150 Rough running
  223. Check engine light
  224. Interior Trim Color Codes
  225. P0453 EVAP control system pressure sensor high
  226. Overhead Console Questions
  227. Driver interior door/window trim piece?
  228. Expedition Overhead Console Install, Part II
  229. Jerk in the rearend
  230. 98 F150 4x4 4R70W Adapter Removal
  231. E Fan
  232. 2000 5.4 - Which head bolt
  233. Knock sensor
  234. Expy Console & Seats into 5-spd. XL
  235. 5.4L 2v Intake Manifold Gaskets P0171 P0174
  236. 2000 F150, 4.6L - no crank, no start? Just a single click...
  237. just put motor in before I start it
  238. Torque specs for clutch assembly
  239. very confused need help
  240. How to: Repair Turn Signals on a '97-'03 F-150
  241. Question about headlights
  242. Temp Gauge Runs High and Oil Light Comes On...Idea?
  243. Driver's side ext. cab door panel removal
  244. Question
  245. PCV Valve
  246. Fuel Pressure at Filter
  247. Buying New Exhuast, Have Questions
  248. Show off your headlight swaps/light add-ons!
  249. Will these trim panels fit?
  250. Ignition Switch Bad or..
