01 Supercrew Differential Rebuild
Old Mar 12, 2014 | 02:03 PM
jfh72866's Avatar
Was going to rebearing my 9.75 differential myself but the Ford dealer is telling me it requires the pinion depth setting tool. Is this correct? Should I rebuild myself or take to a dealer? I have rebuilt many differentials but have never used this tool.
Old Mar 12, 2014 | 04:27 PM
jfh72866's Avatar
Old Mar 12, 2014 | 06:47 PM
Galaxy's Avatar
That's very interesting to me that you've rebuilt "many" differentials and don't know anything about pinion depth! Setting backlash and other items of a "properly" rebuilt rear end is almost an art form. Not impossible with the right tools, but something to be haphazardly thrown together either.
Old Mar 12, 2014 | 08:46 PM
lees99f150's Avatar
I have rebuilt many diffs, just never on a ford. I never used a pinion depth tool. We check and adjust rolling torque, backlash and the wear pattern. A dial indicator and dial type torque wrench is needed along with the specs.
Old Mar 12, 2014 | 09:16 PM
Yes you need to setup the pinion depth to setup the correct ring and pinion teeth mesh.
what exactly are you "rebuilding" in it?
Old Mar 13, 2014 | 08:49 PM
jfh72866's Avatar
I didn't say that I didn't know about pinion depth I just have never had used the ford tool that they said was required. I was going to replace the pinion and carrier bearings.
