No heat blow cold air
Old Feb 28, 2014 | 04:36 AM
pipejob1's Avatar
2003 king ranch no heat just had the dealer change the intake manifold gasket now I have no heat what could it be. Air in the line needs bleeding not sure
Old Feb 28, 2014 | 06:40 AM
pipejob1's Avatar
Temp gauge inside the truck show 1/2 mark could the thermostat be stuck
Old Feb 28, 2014 | 07:55 PM
projectSHO89's Avatar
Go check the two hoses for the heater core. Set the temp control to hot and turn the blower on HIGH.
If they are both HOT, the problem is in the dash (actuator, ****, blend door, etc).
If one is much hotter than the other or both are cool, the problem is either under the hood or in the heater core itself.
Unlikely.
Old Mar 1, 2014 | 06:13 AM
pipejob1's Avatar
It's a king ranch with elec controls. Drove the truck to work the heat for the first 30 mins was fluctuating back and forth. Then after that it's was hot all the way there
