grinding noise
grinding noise
ok so my girlfriend and I went out driving yesterday and at a 4 way stop i was turning right. well someone ran the stop sign which caused me to take the turn more narrow and my back wheel popped the curb. just after that happened we both hear a grinding sound that seems to be coming from the front right wheel well. it only does it when im going 20 and under and when i make a right turn. It doesnt really sound like metal on metal because its not to loud but you can definently hear it. Hope i gave enough info. if not just ask for more. thanks guys
2wd. i have an update unfortunately. I was driving home from school and as I turned my friend and I hear a pop noise and air. Almost like we got a flat tire. and then when i pressed the brakes the grinding was absolutely terrible. Metal on metal noise and very very loud. Braking was almost non existant and the brakes seem to lock up at one point. It only seemed to come from the right front fender well again. Couldnt drive any farther and had to have it towed away to a shop. Anyone care to update me as to what may be going on before the shop can so i can figure what its gonna cost me? thanks
Is it a stock setup (tires, wheels, suspension) or have you changed things up ? If it's not stock then you may have hit something hard on the sharp emergency turn because of insufficient clearances.
Can't say what the damage is but (just a guess) maybe a broken brake line (the pop and hiss), except I'd have expected mention of the pedal to going to the floor and a lot of fluid. Did you notice any of that ?
another update. shop called and said that 2 bolts from my caliper were missing causing the grinding and rattling. so an alignment and $189 later im rolling down the road once i get out of school. thanks for the responses guys
