Knock sensor
Old Feb 23, 2014 | 12:29 PM
cparbuckle's Avatar
Knock sensor
Can my 1997 4.6L still run if the knock sensor is not working or unplugged
Old Feb 23, 2014 | 01:18 PM
Yes, but you will get a CEL and it won't run all that well.
Old Feb 23, 2014 | 02:10 PM
cparbuckle's Avatar
Alright thank you very much.. I will figure something out
Old Feb 24, 2014 | 09:34 AM
jbrew's Avatar
Never tried that one...Why would you?
Old Feb 24, 2014 | 10:23 AM
ishootstuff's Avatar
Maybe a pack rat are the wire. Evil little bastards. They love it under the intake.
Old Feb 24, 2014 | 10:48 AM
MGDfan's Avatar
Hmmmm ... I can see a CEL being set, but why would it run like crap?
It's a piezo transducer, so producing voltage in response to a knock - it's going into a high-impedance input. Simply short the connector with a 10k resistor.
No voltage, no falsely detected knock, normal timing. If you leave the input open, due to it's high impedance it may generate spurious signals fooling the PCM into thinking there is knock and pulling timing.
Of course, you could just replace the dang thing with a good one
good luck
MGD
