Spindle lift?
Spindle lift?
i have a f150 2002 supercrew and i have a 2inch front coil spring lift it on it, and i was wandering if i can put a 3inch spindle lift on it without a bunch of problems. im not sure if i have to put new arms in or not. thanks
Spindles don't change geometry, so need need for different upper control arms. However during the install is the perfect time to replace ball joints and tie rod ends if they're worn out.
