Door Jam Sticker? Can it be replaced?
I have recently needed to get some codes off my door jam sticker i.e. gear ratio codes and whatnot. My issue is that the sticker is not readable. It is severely worn out and useless. Is there a way to get the same info from some other place on the truck or can I possibly get a new door sticker from Ford using maybe my VIN? Sorry if this is a stupid question but I didn't see anything in a few searches I performed. Basically is all the info in the VIN the same as the door sticker? If so I'm good, if not I'd like a new door sticker.
Thanks for the help in advance.
Also If you know a Salvage yard that has their stuff computerized, their Hollander Software will be able to Decode it.
I use to work at a late model facility, & that is how we did a primary inventory of the vehical. Then we did a visual inspection, & deleted anything that was missing or damaged.
Michelle Software is also able to decode it, but the version we use at my place of employment doesn't go that deeply, just gives: Make - Model - Sub-model - Year - Engine - Transmission, & Drive-line configuration.
Hell, I think it may even say what color the car was suppose to be? But since I work under the car that is pointless info to me.
The VIN can identify the exact build sheet for your rig, but you have to get it from the dealer or the manufacture directly and that will cost you some $$ I'm sure.. Standard "VIN DECODERS" off the internet do just tell you the basic stuff as GLC said.. It's the actual number at the end that tells them what exact vehicle you have..
Good luck!
Mitch
Good luck!
Mitch
Thanks for all your input. I will call Ford no Monday and see what they have to say. If I can get it I will post it here and let you know how much it costs and whatnot. Thanks again...
