View Full Version : 1997 - 2003 F-150
- Weird and wacky window issues!
- want to run Nitrous
- Checking Tranmission Fluid
- rough idle/lacking acceleration/power
- To Swap Engine or Body, Need your advice please!
- Help Please, brakes sticking.
- Is buying a 2003 4.6 4x4 5 speed f150 with over 200k but in great shape worth it
- Questions on questions. My quest.
- 1997 5.4L Spark Plug Question
- Tire Sizing 1998 F150 Lariat 4x4
- Steering shimmy around 45mph
- Oil gauge light
- 97-98 4.6 to 5.4
- Beefing up springs/shocks for plowing
- Almost got stuck
- Rust on windshield edge
- Heater Hose Connector Corroded
- Stock PI motor HELP
- Blend door porblem
- 2002 Ford
- 98 F150 5.4 2wd Starting issue!
- runs lousy and allmost dies
- 1997, transfer, case, 4x4, low new motor install
- 98 F150 intermittent Sputtering
- Add a leaf
- Startup Sequence issues
- 98 f150 4.2l 2wd
- Gas Gauge not working...Sometimes
- Wheels making metal on metal sound.
- 1999 f-150 electrical problem
- Guys!! I need help!!!
- 2002 f 150 4x4 problems. Any help
- 98 4x4 dash light
- 03 with 5.4l, getting error codes, wondering if they are likely related
- 99 f150 4.6 fuel pressure
- Broken MFS connector (turn signal switch repair)
- 2000 F-150 Flasher replacement tutorial
- Need some help with my 02 f150!!!!
- Bi fuel regulator
- 97 4.6 f150 transmission problems
- EATC Main vacuum line firewall location
- What paint did you use on your grill?
- Restoration Locations for F150?
- truck cranks but will not start no power to inertia switch but power at relays
- Weird window button
- Propane tank removal on f150 bifuel
- Won't turn over
- Instrument Cluster lights not working
- A/C quick connect hose removal
- 1998 brake hard line replacement
- Instrument cluster quit-99 F150
- Turn Signal problem
- 01 4x4 Hub & bearing mount bolt
- 4wd pulls right
- Fuel Pump or not?
- power steering pump
- Bucket TO Bench seat conversion in a 2002 F150
- P1289, P0336, P0300, P306, P0316, Help
- Greetings from Alaska!
- P0171, P0301, P0316 Codes - Possibly EGR
- Truck stalls after restart when shifting into drive
- new member of the 400K club
- 2WD broken front shock tower / mount
- Really need advice on my truck
- 4x4 inop.
- New F150 owner, saying Hi!
- Clutch
- Oil pressure issues
- Tailgate handle for 2001 F-150 Lariat Supercab
- 2001 F-150 V6 wont start!
- 97 f150 cruise control
- Airbag Dash Cluster Light On and Off
- Part no pp-gf30
- 2003 F150 Super Crew 4WD w/6" Fabtech, WHAT FRONT SHOCKS?!
- Changing the serpentine belt 2000 F-150 4.2 liter
- Lifting the front using Springs/Shocks
- Speedometer
- Intermittent odometet Display
- Trailer light inoprable right side
- A little idle shuddering
- p1450,p0171,p0174
- 98 F150, 4.6, codes Po153, P01151
- 2001 won't start. Any help appreciated
- 2000 4.6 rough idle and surging
- No cruise control
- Fuel Trim and Vacuum lines
- idling issues
- coolant leaking out of reservoir
- Electric mirrors
- 97 F150 brake bleeding nightmare solved
- 1998 4WD Ford F-150
- 2003 F-150 Questions inside 👇🏻
- Maybe bad cats?
- Advice on buying an 2002 XLT 5.4 with 50k miles
- 01' F-150 FXoffroad Lariat suspension replacement parts?
- Are seat bolt patterns the same between this and the NEXT generation trucks the same?
- Anyone ever swap in a 6r70/100?
- Mud truck problems
- 97 F150 Flashing Overdrive light.
- 2000 Ford F-150 4.6L cranks, no start
- 2001 xlt 7700# Radiator
- New member truck problems
- Starting issues
- rust prevention/removal?
- 97 f150 shifting problem after hitting a washout.
- 2003 rear window detached from cable
- Few body lift questions....
- runs really rough but only after an hour or so
- 97 F150 2WD long bed standard cab fuel lines bad shape
- Alternator not charging
- 2001 F-150 5.4L Sputters & surges above 1,000 ft elevation
- location for a 1997 4.6 knock sensor
- 2001 5.4 making knock sound
- 2000 rear end in 1998 truck
- Just a few questions
- 2001 f150 supercab 5.4 - fuel pump primes, cranks but no start.
- 01' F-150 7700 Front Wheel bearing options
- 03 F150 Front Hubs not Disengaging
- Lost a bolt
- New motor cranks but no start
- 2001 F150 lift - just another inch or 2
- I damaged passenger window rail when replacing door actuator
- Turn Signals Not Working
- Need help with a vibration in my 99
- Transmission or ignition problems
- Wireless canopy locks
- Help!!!
- 2006 seats into a 2000
- Questions about swapping out motor
- 2 part question coolant leak and head gasket
- Help needed with electrical issue Please`
- please help with cruise control
- 1998 Ford f150 4x4
- 2003F150V8 AC Problems-Can Anyone Help?
- Drivers electric window not retracting
- F-150 help
- Chassis Brace
- What's the value?
- 03 F150 Slip on Take Off
- 1998 F150 V6 Setting for a year
- Found an abandoned 1997 Lariat. Keys in it. 59k
- Changing rear end gears
- 98 F150 4x4 Rear Differential Rebuild or Replace
- 98 F150 4.6 Fuel Pump
- 1998 4.6L no start w/ good batt, new alt, new sol, & new starter
- Flywheel noisr Z
- 2wd to 4wd conversion
- 2001 crank no start sometimes
- Gas Gauge Getting Stuck
- Suggestions to diagnose codes p0172 and p0175
- Parking lights and dash lights don't work
- Yet Another Oil Filter Adaptor Leak Question
- How to find my baby a good home?
- HEGO Sensor Fuse
- Lots of problems after clutch change
- 98 F150 Fuel Filter and Line Problem
- Compatible engines for 1998 ford f150.
- Truck shudders at all speeds, even in park.
- Cooked ECM?
- need some advice
- Fuse box replacement - AF vs. EF
- 4.6 to 5.4 swap
- 2003 5.4 Install Question
- 2000 f150 suicide doors
- 1998 F150 Shift lever is stuck in park! Please help!
- Please Help! Stalling.
- F150 Guage lights completely stopped working
- Crazy eletrical problem
- Newbie here looking into my 1999 4.6L F-150
- Rocker panel sleeves 2000 f150 supercab
- 1997 f150 idles high
- 1997 engine temp up and down oil light on and off
- 5.4 Engine squeal under load
- 2003 XLT FX4 Supercrew Gas Mileage
- 1997 F150 4x4 5.4l Transmission Range Sensor
- 7.5in fabtech lift
- 2000 F150 XLT 4x4 Tire / Rim help
- '98 f150 xlt triton 5.4l cranks but won't start
- multie codes/ O/D light flashing/ lack of power
- 01' F-150 FXoffroad Lariat COPS?
- 2001 Ford F-150 super crew
- Trouble with my ford
- 2002 F150, turn key and nothing happens?!?!?!?
- Need Help!! Truck I inherited has no power to fuse panel
- Improve '03 FX4 handling and suspension?
- 14 PC suspension kit..
- Headlight upgrades
- Where are the FX4s? (Tenth gens 97-03)
- 1997 F-150 4x4 4.6 running rich
- Stuck
- Inherited a 97 4wd- runs great, but it's rough- What's first thing you would do?
- 2001 F-150 Lightning
- 2002 F-150 5.4L Coil Pack Recommendations
- L supercharger swap
- Fi50 Center Console
- 2001 5.4 Cold Idle Speed Ramp
- 4.6 or 5.4
- Adjusting tilt steering turns off headlights
- 1997 f150 NEED HELP !!!!!!!!!!
- 1998 smoking on start up after using seafoam
- 98 F150 Loses gauges...then power ??
- 2002 sport model suspension ?
- 1997 F150 4X4 relay randomly clicks on and off
- 2002 F-150 SuperCrew - Exhaust and Engine Missing Questions
- 2001 5.4 idle issues
- Heater control questions
- 2000 f150 cupholder Mod
- EGR issues
- Sooomeeebooiddyyyy
- 2003 XLT FX4 Super Crew Height question?
- 97 Part identification
- po1299 2003 f150 4.2
- 4x4 not working right!
- New bearings or just rotor replacement
- 1997 F-150 4low
- 2003 f150 4.2
- How to know if truck is already had level kit
- Input and Advice Upgrades on a 99
- Not bad for a 'dead' truck!
- Installing cargo light in f150 1998
- Shaking when braking over 30 mph
- head problems
- 03' f150 4.2 (tune up/advice/info)
- Wipers not working
- Instrument Cluster/Radio Lights not working
- 1998 F-150 Spark Plug Issues
- Spark plug blow out
- Code C1284
- 2001 4.6L oil ligjht flicker
- What's it worth?
- HELP~~99 F150 Turn signals DONT WORK ~HELP
- Cab fire
- 1997 F150 2wd XLT Styleside
- Sinking Break Pedal
- Edge Evolution and trans temp PID
- 97 bumper Fog lights
- Valves
- Headlight Tab wont come up
- Codes say oxygen sensors but I'm suspicious
- What's this mystery noise?
- 2003 supercrew lower stripe tape
- Thought I had fixed the $x4
- Electrical help(manual to power windows)
- Troublesome problem!!
- Battery light
- changing oil pan gasket and dropping front axle
- PCM Harness Damage
- 99 2v 4.6 to 04 4v 5.4
- Ignition key
- 97 5.4 2wd scab 305/70/16
