Turn Signal problem
Turn Signal problem
Hello Folks!
I have an 2000 F-150 4.6 V8 XLT that the turn signals have started acting crazy on. Sometimes they will blink a time or two and then they will stop. If I jack with the handle sometimes I will get them to blink but only a time or two. The emergency flashers work fine. Is the emergency flasher the same flasher as the turn signal flasher? If so then I assume that the flasher is fine. What should I check for next? Perhaps the actual turn signal switch?
Thanks!
Thanks!
Since it was a cheap quick fix I replaced the multifunction turnsignal switch... no luck. Where do I go from here?
Last edited by chuck gibson; 09-01-2017 at 10:19 PM. Reason: Spelling corrections...
I appologize if I offended you. Due to physical problems it is difficult for me to get under the dash so I spent the $20.00 on an aftermarket MFS and tried it. As I posted, it did not fix the problem so I took your suggestion and replaced the flasher. BINGO! It is fixed. I found a great video that was short and to the point that I am going to try to share with this group. Thank you so much for your help.
