A/C quick connect hose removal
On a 2000 F-150 4.6 I am in the process of replacing the A/C compressor, drier and oriface tube. I am stuck trying to remove the drier hose leading into the evaporator. I have a plastic release tool that I have used in the past to remove the heater hoses but I have fought this coonection for over two hours and I need advice.
Thanks in advance!
Chuck
Thanks in advance!
Chuck
Thanks for your input!
I probley should have. I can't complain much. This old truck has 545,000 miles on it and the air conditioner parts are all original.
I received my new Motorcraft condenser today. It has a notice in it that the freon charge qty will be lower. The OE system called for 33oz. The new condenser calls for 1.85 lbs. or 29.6 oz.
Have any of you guys heard of this? Does the condenser determine the amount of freon in all systems?
Thanks!
Thanks!
