View Full Version : 1997 - 2003 F-150
- 99 F150.....wont start
- Off Road Winch Bumper
- 2WD Mudding
- Torsion bars
- Coolant temperature goes cold while driving
- 1998 f150 what can i sell for
- Bad Idle???
- Max Towing
- 2003 supercrew.. want to change rear end gearing to 4.10
- Common Trans or LSD Problems with these?
- catalytic converters
- ford says use 5-20 can i use 15-40?
- what shocks after lift?
- replacing headlights, how to?
- 250k on a 2000 5.4l realistic?
- Rough Country Lifts?
- Nerf bar suggestions
- 6'' Fab-tech Lift For a 1997 F-150 Manual Transmission?
- Won't start
- idler part #? and where to get diagrams??
- Wheel Bearing Assembly
- new to the site....take a look at my f150
- no start, no click
- Disk brake upgrade
- Vacuum Sounding Pops from Under Hood??
- Maintenance Help
- Key Bob Remte
- Can someone identify this part?
- bad noise, were to start looking. guess I over did it
- what brand of oil?
- Win a Sony Playstation 3 (PS3) or Gran Turismo 5
- Is it worth it
- Building a box for my two 12" fosgate P3S.
- kind of a stupid question
- Starter hangs up
- looking to buy a 2001 f150
- Biggest torsion key ripoff
- clusters on 1997 to 2000
- Truck pics
- 97vs03 Rear window advice
- 4X4 Not Engagging Fix
- What's the magic number - bed weight?
- Starting proplem
- 2002 Blower motor fan speed only works on 3 & 4
- 1998 4.6 Engine missing - can figure out why?
- Connecting power to backup monitor.
- Brake Lights Not Working Help!
- My new to me truck 2001- Super Crew
- Broken shifter knob!!!
- Under the dash Questions
- HELP! Do you know which bulbs for speedo?
- 4x4 engaging by itself (at random not good)
- Truck wont start...help needed asap
- AARRGGHHH! Code PO0171 AGAIN!!!!
- Rough Morning Starts
- Vibration Makes Me Hate My Truck
- positave camber issues
- edc question
- can overfilling gas tank cause po171?
- 99 F150 door handles
- no heat and not sure what to do
- what grill is this?
- Ball joints & bushings are done.
- Help with grill painting method
- Remote start
- heat problem - no heat just changed the core
- Codes P1131, P1151, P0171, P0174??
- need some help with headlights
- e-fan question
- Front End Allignment
- The infamouse cylinder 4 misfire
- Bull Bar brackets?
- reference for shocks
- replacing o2 sensor
- 22" wipers instead of 20" on 02?
- What trucks say 4x4 on the side of them.
- 4x4-Front axle actuator doesnt engage on its own
- Nerf Bars?
- long term fuel trim
- Headlight Help!!
- lean code p0171 and p0174
- 2003 Ford F-150 STX Question?
- Replacing gas tank woes
- how to install aftermarket tachometer
- Dropping the transmission pan...
- Odd dual hella light problem
- Pic Request Please
- 4x4 troubles
- Low pressure A/C switch
- 97 5.4 missfire
- Spindle lift question. Do I have to install the blocks to lift the rear?
- Slop In Rear Driveshaft At The Back Of The Transmission
- Navigator handles into a supercrew
- How do you rebuild a fuel pump
- 4 hella 500ff's behind grill?
- heater core
- 4.6 engine knock
- 4x4 problem
- Street tune lights
- Connecting Rod????
- Engine Replaced?
- Floor mats
- P0704- Clutch Switch Input Circuit Malfunction
- 4x4 not engaging
- Searching the web for different tire looks...
- Had some fun today
- 99 f150 wont run.. thinks its being stolen HELP!
- 4X4 problems...help plz!!
- quick question
- Got fuel tank lowered
- Front end vibration problem
- Please help with battery/electrical problem
- Thermostat change
- Need help!!!
- lookin for a lift
- Questions on Combustion In Cooling System & Camshafts???
- anyone know where to buy an engine block(new to newish)
- Need a hand with remote start issues!
- Efan and UDP Questions!
- 2002 F-150 5.4 P0172 Code To Rich Bank One
- how can i do it?
- Expy Overhead console
- Changing my fuel tank, questions!
- 5.4 swap power steering problems
- Gauges max out when starting truck
- Burning Rubber Smell
- protuninglab headlight kit?
- tranny temp gauge on heavy half ton
- What to do, what to do?!
- COP problem or just plugs
- Hmmm. Whats that kid up to?
- Fuel pump is supposedly bad HELP !!!
- Photoshop request
- need someone with 01-03 to do me a favour
- F150 Manual To Auto conversion
- Brake ???
- New pics with a few inches added!
- ebay Coil over plug units
- 18" oem wheels
- Speedodometer HELP
- F350
- Project Purple People Eater
- 2001 f150 XLT cruise control switch
- Correct spark plug
- Remove steering wheel
- Leaf spring squeak
- can a 6" and a 2.5" level clear 37s?
- Offset and backspacing question
- Anyone have 4k they wanna give me?
- Super Duty Seats???
- Cam Cover/Valve Cover Tightning
- How to tell...
- Jeff R.'s Progress Thread
- rehanging rear view mirror help
- can someone explain all this headlight mumbojumbo...
- Question about removing TB spacer
- 97 f150
- harley headlights... SCORE
- Persistant Squeel
- 2000 F-150 4.6 with heater core issue
- 2003 4x2 HELP
- New Wheels & Toyo A/T Tires also vs BFG A/T
- 97 4.6L off idle miss cel on
- will this speedo work on my truck?
- A new addition
- URGENT Correct Plug Gap
- Replace starter, getting rattling metal sound
- 1999 F150 5.4 exhaust rattle?
- Stock aluminum hoods & Steel hoods... replacing
- wild lightning... might give you ideas
- did mechanic fix my truck???
- DirtySCREW is BACK!!!
- 98 driver door motor
- black or chrome for steps/nerf bars and bull bar
- suspension paint
- 97 in the mud
- time to re and re 4.6
- Fog light mod
- automatic headlights??
- green wire for 3rd brake light
- why no ethanol?
- Emergency brake repair manual?
- RED Dash lights
- I really Dont See what took Jake so long...
- shift cable
- Truck spits and sputters,when accelerating
- Complicated. Seeking Advice.
- Nitto Tire on Facebook, LIKE to win tires
- The 100k mile tune up?
- New tires, now I need some speedo help..
- new guy in ga
- wiper problem
- Stock 4wd Foglamps on a 2wd??
- need help quick!!! clutch slave cyldr ?...
- Painting dash help
- Engine VIN
- 99 4.6 auto over drive questions
- my truck/project, and request for pics/opinions
- any one with projector headlights?
- Heater core tips/new problem
- Cross Country Move
- Do you have a rollpan?
- Stock wheels with lift?
- 4 wheel drive seems slow to engage on 2003 lariat fx4 supercrew
- what should i do with my exhaust?
- heater core quick connects
- 71' boss 351 tribute truck
- mechanical question
- New kicks
- Leaky Rear Window
- New To The Forum and looking for help
- HELP!!!!!! 2001 Ford F150 XLT
- PATS key bypass for remote start?
- Quick Question
- Fuel Pump Conundrum
- Coupon for a scanguage
- Started my first mod.
- How To: Replace auto shifter boot
- Fuel tank pressure sensor
- Thinking About A New Truck
- URGENT!!--need some help guys
- Funny noises
- Block size for RC 5" lift
- Raptor's Rebuild Thread
- New grill and 10k hids!
- After-market Front bumper for 03 F150 Fx4?
- Moose_God's 00 5.4 4x4 build thread
- my truck got in a accident
- Couple of updates! (pics)
- Bigger Wheels
- Wont Pass emissions test
- iac hookup
- beach pics
- Hello F150 Online comunity
- ScrewGreen's Build Thread!!
- LED dash lights
- misfire
- Pretty Sure I Got Sideswiped Today...
- Gas mileage question
- few problems
- Odd Heater Problem
- ARB Air Locker?
- Weather Strip On Back Window
- headlights lighting.HD question
- Third Light. Rear of cab Issue!
- white bumpers
- wipers are working on their own...
- need info on a 2in front drop
