2002 Blower motor fan speed only works on 3 & 4
Old Dec 4, 2010 | 01:18 PM
topgun330's Avatar
My 2002 F-150 superCrew 5.4L's blower motor (heat and A/C) only blows on the 3rd and 4th position, not on 1 and 2. Is it the fan speed control **** thats bad or the blower motor itself? I have not checked into anything yet and would like to know a good place to start. Any help would be greatly appreciated.
Old Dec 4, 2010 | 07:01 PM
noggin7717's Avatar
https://www.f150online.com/forums/ar...igh-speed.html
Old Dec 5, 2010 | 12:03 PM
topgun330's Avatar
Awesome
Great reply, thanks! I have not replaced the parts yet but it sounds exactly like what i have going on. Great info sharing.
Old Dec 22, 2010 | 04:02 PM
mcline86's Avatar
Had the same problem on my 97 5.4.......only worked on speed 4 (high). Just about an hour ago i was in the dash, adjusting the cable that goes to the indicator that tells you what gear your in on the column.
I was putting everything back together and the fuse pannel cover kept falling off so i stuck it on there and punched it. instantly now i have fan speeds 1,2 and 4........ very strange, but im happy!
Old Dec 23, 2010 | 04:08 PM
replace your blower motor resistor
Old Dec 30, 2010 | 09:35 AM
mcline86's Avatar
started working only on high again. got a resistor at car quest for 19 bucks. my wiring harness was melted to sh*t too but no one had it except ford and they wanted 50$ for it. so i only did the resistor, ended up working fine i now have all 4 fan speeds. thanks guys
Old Dec 30, 2010 | 07:58 PM
Ryan2KRedL's Avatar
Great info!
My 98 F150 had similar issue start today.
Fan only worked on high.
I went to Advance Auto parts and bought the blower motor resistor (3 hole style) for $22.
Installed it in less than 3 minutes.
Voila! Problem solved!
Thanks F150online.com!
Ryan
