97 5.4 missfire
I think the gap is ..54 but that should be on that tag thats right in front of the radiator. Why not replace them all? one at a time? You could also ask auto zone or whatever. they'll know the gap for sure.
#1 is passenger side front..
the truck isnt anything were trying to keep around its pretty beat and has a ton of rust and miles. just trying to get there the winter plowing with it. passanger side front closest to the radiator is cylinder #1? great thanks jethat
Plugs are sp-479 gaped to .54 and can be found at autozone and other places for about $2 each I think.
Yes
No problems removing them but they must be put back with no anti-seize torqued to 28ft/lb is what is now recommended by most to avoid blowing out a plug. Plug breakage while removing was in the 3v motors.
You aren't going to find them that cheap. The part number for a 97 5.4 is SP459 and Rock Auto gets $4.26 for them.
My bad. Thought it was 98. confused with a similar post.
Fixed the missfire, runs great now and doesnt have the shakes anymore. May have only been the spark plug seeing the old one had more than double a .54 gap and almost nothing left of the electrode.....lol but whatever changed the coil and the plug and shes fine. Thanks again for all the help/info guys.
