Burning Rubber Smell
Old Nov 18, 2010 | 11:19 AM
dcmband03's Avatar
I have a 2001 F150 4.6 XLT and recently i have noticed a burning rubber smell coming from the engine compartment. But looks like the lower half I cannot see from above. I have been doing longer rides lately and noticed it has been getting more noticeable. Does anybody have any idea what it could be?
Old Nov 18, 2010 | 11:24 AM
SlammaJamma's Avatar
Coolant level staying where it should be?
Also, check your belt for any obvious spots of wear.
Old Nov 18, 2010 | 11:30 AM
dcmband03's Avatar
Coolant levels are fine and i just replaced the serpentine belt about 3000 miles ago
Old Nov 18, 2010 | 11:35 AM
thejake1989's Avatar
check to see if its not a locked brake caliper and it the pads burning
Old Nov 18, 2010 | 11:37 AM
dcmband03's Avatar
I'm assuming the best way to check that would be to take off the front tires and hit the brakes to see if they are releasing?
Old Nov 18, 2010 | 11:39 AM
that or next time you drive check by the tires. if it is the brakes its a MAJOR issue and you need to fix it fast before it gets real expensive with replacing parts
Old Nov 18, 2010 | 11:52 AM
dcmband03's Avatar
to fix it if they are locked..would be just to take off the brake pads bleed the lines some and hook everything back up?
Old Nov 18, 2010 | 12:31 PM
dcmband03's Avatar
Just checked it out brake pads are not rubbing at all
Old Nov 18, 2010 | 01:02 PM
jhimer's Avatar
This could be a burnt oil smell from a valve cover leaking.
Just a thought.
Old Nov 18, 2010 | 01:42 PM
dcmband03's Avatar
Just a thought.
This is what i was thinking too assuming that burnt oil smells like burning rubber
Old Nov 18, 2010 | 02:26 PM
Nettershakes's Avatar
So you said the brakes werent rubbing, but next time you smell it and hit a stop sign or stop light, check the wheels for any smoking. I started smelling that burning smell and when I looked at my drivers side front there was smoke pouring out. I guess the caliper just got stuck for a bit. Its good now.
Old Nov 18, 2010 | 04:31 PM
97madness's Avatar
just a random guess but did you have the recall for cruise control done?
Old Nov 19, 2010 | 08:10 AM
dcmband03's Avatar
The repair for the cruise control was done. I also checked yesterday after driving and it is definitely not the rotors. I am thinking that my valve cover might be leaking so i have to wait till this weekend to check it out.
Old Jun 17, 2012 | 11:17 PM
BlackFerret's Avatar
Delete!
Last edited by BlackFerret; Jun 17, 2012 at 11:22 PM. Reason: Delete, stupid me didn't check the date!!!!
