View Full Version : 1997 - 2003 F-150
- NEW Pics! BuckTruck
- misfire, me too!!! P0301
- Anyone Plasti Dip 01-03 Lariat Rims
- Misfire P0316
- How to replace Sway-Bar bushings/spacers with aftermarket ones.
- Misfire Error Codes & Check Engine Light
- 98 f150 low power and mpgs
- P0304 misfire times 2
- Tire or truck problems? Advice needed.
- Radio ?
- Thinking, supercrew with 6.5 box project
- Seat swap F-150 full bench to captain seats HELP!!!
- 2002 F150 4wd engage doesn't engage
- 2003 Screw Speedometer stopped working
- changing things up on a budget
- Kid on the way. I have a regular cab but want a super cab
- Misfire got me crazy!!!!
- New Truck!! Opinions welcome..
- 2001 F150 Scheduled Maintenance
- No fuel pressure when cold
- Emission help please!
- Where to find this harness.
- Chassis Saver
- Fixes for broken coil and fuel injector plug/connectors
- 6 inch with 37s? Clearance?
- Gears install- Is this a good kit/ price
- Swapping center console to a jump seat
- t-case
- Bedliner Paint Job
- So Glad to be Back Here
- Road trip to Montana
- 10w30 oil in the 5.4
- $450.00 tune up???!!!
- double dinn head units
- Larger fuel tank
- Not your typical horn issue
- Rocker plugs and running boards
- Fiberglass 1/4 console build (for cb and aux switches)
- Beating a dead horse
- Needs help...
- Wheel help--again
- Noise from or around valve cover? (video)
- Does anybody have a write up or could tell me how to delete ABS?
- Keep your HU on after the key is out(until doors open)
- Hi Everyone - My truck has issues : (
- Drl
- horrible gas milage
- Any 1997 4x4 front bumpers for sale?
- Power windows struggling (video included)
- Disable perimeter lighting (low beams) when using keyless entry
- Pics of my rig
- Just got a dealer quote
- will 35s fit?
- 4.2 no start
- sputtering
- Cruise control still fails after recall fix
- Squealing - I've tried almost everything.
- What is the best fuel pump for my truck??
- #Patman is back, and has new mods
- Pace Edwards roll cover
- PTM cowl
- 99 F150 4.6 to 5.4 swap
- Screw Rear Center Seat Belt Question
- 2000 2wd 4.6 with cops into a 1997 4wd 4.6 non cop???
- Crank, No Fuel
- Fuse blowing when brake applied
- Should I sell it?
- New truck
- Rain Channels
- Stock Fender Flare Issue
- THEFT LIGHT NOOOO help!
- Plasti Dip for grills?
- Rear axle seal leaking
- project *no payment*
- Spacing between tow hooks?
- wheel bearing race problem
- 2002 F150 tires & rims
- Were the Fx4 options included on a King Ranch in '03?
- Lift with stock wheels?
- 02 F150 door chime and radio problem
- 2003 2WD Clunk Bump Feel
- 97 f150 4.6L cold weather no turn signals/hazards
- Restricted exhaust problem/solution
- 1997 F-150 Speedo, Cruise & ABS Troubleshooting Revisited
- 2000 F150 Intermittent Starting Issues
- help!! i want to fix up my 2002 f150
- Grind/Drag Issue
- AC Bypass Option
- 2000 f150 airbag rcm question
- 2002 w/ siezed motor
- Would it fit?
- Anyone running 295/75/16 on stock height 4x4?
- New to the forum! I got a few questions about buying an f-150!
- Freeze Plug Help
- Springtech 6.5 lift
- 12" bullet proof suspension lift for 97-03 2wd
- Playing with Plasti Dip
- small interior 'square' snap-in panel/cover goes where?
- Truck issue need help with
- Few question on installing custom exhaust from headers back
- Trans Swap
- AC Compressor removal
- 2003 Scab FX4 5.4 Makeover (Work in Progress)
- Great news!!!
- Stock Ride Height 4wd
- Brake Questions
- Fuel octanes
- 1999 F150 trouble
- Few lift questions
- '01 4.2 l v6 seems to shudder at higher speeds
- modding the fitty
- Couple of questions
- New Used F-150 Owner Questions
- How can I remove the metal plating underneath the back seat
- P0420 new cats
- noise - psgr side engine compartment
- Oil Cooler lines
- Need Help with FX4 Flareside Pictures
- Leaking coolant on top of Engine Block?
- Window motor success
- Fan Blower won't work (no resistor)
- 2002 buying questions
- anyone running 285/75/18?
- Back after 10 years
- Gap guards on body lift. . . yes or no?
- Can anyone shed some light on this question?
- 98 Pawl Probs
- 285's with a 6" lift?
- transmission
- Need advice on CB radio and 1 or 2 whips?
- Worn front wheel bearings tripping ABS light?
- Won't Start - Coil Pack wire?
- Is this the Upper/Lower Heater Hoses?
- Help please!!
- 4HI operation
- navigator front end swap? 98-02?
- gremlins
- Bad rear axle bearings?
- 2003 F150 FX4 "Truck Make Over"
- 97-03 window motor replacement how to
- where to buy
- Hit a deer Thursday Morning!
- Rear end gear ratio????
- Need window motor drill locations
- well im back ...
- Shift Lever - Any Ideas?
- Need HELP identifying which seat cushion
- Rim help for old guy..
- No power at high RPM
- Anyone using HHO boost system for mileage gains?
- VERY poor gas mileage
- Rocker Arm Issue
- post your prerunner
- Worth the while 3 inch lift using new torsion bar keys?
- 1999 F-250 Light Duty to 1999 F150 Crossover
- O2 sensors
- Cranking Torsion Bars
- 4 Year Update
- F150 Bumper "Center Step Pad"?
- Truck died while driving. IT DOES CRANK but No Spark, No Fuel.
- Any one have pics of there lifted 2wd riding on 37s
- 10" wide with -24 offset, need advice today
- Anybody Know What This Is?
- 2003 FX4 shocks
- Aal
- Need help with depo fogs
- 4x4 Wont Engage
- Leaf Spring Shackle
- Any interest in 2003 Heritage Edition Emblems?
- Before I hit that "checkout" button...
- What would you do?
- Bed Liner On Chrome Bumpers [Pics]
- For you guys that like to roll with your dog...
- POR-15 is it worth it?
- Weird ABS vibration in pedal
- muffler question
- craigs list find
- Hauling water
- 01 7700 Tire questions
- My 97 5 speed and my other toy
- Looking for Seatbelt "Trim Cover"
- Tow a 5th wheel with on 02 fx4???
- 2000 F150 5.4 4x4 Starter Questions
- door cylinders - to replace or not...
- 3" body lift clearance question
- Where to Start...............
- Camshaft Bearing Cap Question
- suspension
- Speedometer
- Engine swap
- 97 f150 wont engage rwd until swiched to & from 4x4
- abs light
- new ford backyard mechanic
- Wheel spacers
- Need a picture.
- 1997 F250LD Electrical Issues.
- wiring problem?
- 2001 F150 starting problems
- 02 f150 Wheel Bearings 4x4
- wheel Adapters
- 2001 Super Crew Electrical Issue
- 1999 4.6l Sudden Overheating Problem
- Decided to hit the mud [Pics]
- Day time running lamps
- Possible build
- 1999 Won't Start at Times
- suspension question
- battery drain
- 2002 F150 Temp 160 degree problem
- 97 f150 lariat driver window no up/down
- Stock 6 Disk changer behind the seat.
- Bumper idea's?
- looking for scabs with lift blocks and cranked t bars
- headlight question
- Lost power/Won't accelerate
- 97 engine swap to a 98
- Stuffed
- valve cover removal
- Hailing from the Dirty South
- Superchips 4.6L tune worth it?
- After about an hour of searching... Whats the biggest size tire i can put on stock?
- Body lift
- Used Gears
- Gas Smell in Garage???????????
- Truck wont start
- What MPG's are you getting with your 4x4 S-CREW?
- New to Forums and F150
- My 97-99 F150 custom grille, show me yours!
- opinions on 5 inch exhaust tip
- Opinions wanted! DUI, ACCEl, MSD, tuners, 99 4.6
- new to forum thinking about wheel spacers
- P0171 & P0174 on 5.4L 2002
- My new project
- running boards
- A little help
- Starter problem?
- Headlights dont come on when I unlock the doors
- Exterior lights won't turn off.
- Door lock problems
- Idle Surge with A/C
- brake lights turn off when pedal is fully pressed
- Secret gas mileage tip?
- 2000 f150 e-fan questions
- a little tire help... opinions wanted
- New system: 3 12s on 3000w
- 2002 f150 xlt
- What's behind the rear window trim?
- What's behind the rear windo trim?
- Supercrew use same frame as supercab?
- 03 5.4L crew problems with odemeter reading dashes
