sputtering
Change the plugs, they are overdue. Motorcraft SP479, no antiseize, 28 ft/lb torque, use dielectric grease in the coil boots when reinstalling. See if there are any codes when you are over at AZ buying the plugs ($3.49 each) and grease. Buy a bottle of Techron and throw it in the gas too.
Just came from AZ, they checked for codes and there were none. Before I put the fuel filter on last weekend, I put a bottle of fuel treatment in the tank and filled it up hoping that would help. Guess the plugs are next, how big of a job are the plugs?
Your first time will be a PITA. Expect 4 to 5 hours. A quick search here will bring up a 'how to" with pictures. If you find the how to I used do not use antiseize like glc suggested.
