My 97-99 F150 custom grille, show me yours!
Old Feb 9, 2013 | 08:00 PM
ratherBstroked's Avatar
Thinking I was tired of the ugly grille on my 1997 f150 and I love the RBP look but I would never pay what they want, not even a quarter of the price so I figured I'd make something similar, it cant be that hard to make. This is a prototype grille and I will not be using it as I didnt completlely like the turn out but the next one, which I've already started will be similar but made out of steel and not aluminum. I want a heavier mesh for the grille so I'm still looking. This did not cost me a penny as I used all material from my work and I had an extra can of bedliner hanging around. Shoot me some comments on how I can improve this little project. Mainly looking for an alternative for the studs but I'm not looking to buy those "percy" studs. Keeping a low cost is what I'm looking for. Sorry I have not put it on my truck yet as we just got about 2 feet of snow so It will have to wait. Stainless M6 allen bolts and was going to bolt it over the stock grille but cut out the middle slats. Like I said, this is a rough idea and will only improve and the steel one will be powder coated. Thinking about making a stencil and airbrushing a cool logo in red on the mesh.
Even post up pictures of your custom grilles and maybe I will change direction. Seems like theres nothing out there that looks to sweet. Not into those billet grilles, half the trucks on the road up here have them.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Feb 10, 2013 | 03:32 AM
JMC's Avatar
JMC
25 Year Member
I painted the honeycomb to match the body. Hardly any snow in Windsor. Cheap mods? Port the TB. Gasket match heads and intake manifold. Replace the front cats with mandrel bent 2½ inch pipe all the way to the manifold. Run synthetic oils. It starts to get expensive after that.
Old Feb 10, 2013 | 08:50 PM
Wasn't really asking about performance mods but thanks for the input. I'm actually pulling the 2wd off the road this spring so I will be pulling the motor. I have to do more research BUT I'm looking into turning that motor into a carby motor for my 97.
Old Feb 11, 2013 | 02:25 AM
Buxton91's Avatar
Although not my style, great job. I've been wanting to make one for mine but something that sits inside the grille shell and not flush with the surface. If I don't ever end up swapping to the 99+ front I might fab something up.
Old Feb 11, 2013 | 05:28 AM
Yeah buxton, that was my initial thought to make the grille fit inside so I went ahead and made one but did a 1 1/4 border. It looked too small, kind of out of place to me though. Thought about swapping to the newer front ends too as my 2wd is a 2000 and I'm pulling it off the road this spring.
Old Feb 11, 2013 | 08:41 AM
dirtrider596979's Avatar
You must have read my mind, this is the exact look for a grill i wanted to make for my truck. I here ya on the RBP pricing. I could only find ones for the 04 and up f-150s but they were like $800, so i stoped looking.
what did you use to cut out the aluminum? Looks realy good
Old Feb 11, 2013 | 05:52 PM
CManHugh's Avatar
Looks real good, RBP probably make a 700% profit on whatever they make. Can't wait to see it on the truck.
Old Feb 11, 2013 | 09:06 PM
Thanks for the compliments guys! I took the outer dimension measurments and firgured the size of the solid border (2") so that gave me the inner dimensions which I had the automated punch at work do for me then I took it to the metal shear and cut the O.D. I am a welder and work in a metal shop so I have the luxury of many machines except of course something like a cnc plasma or routering table but you can easily cut it with a plasma cutter or even a jigsaw if you have a very steady hand and sander or de-burring tool to clean it up. Took me less than an hour to make. I will be making a better looking grill. Same idea but I am going with a satin coat steel (14g) and overlap mesh(maybe 16g). BRP definatley makes a huge profit but one big expense is those "percy" studs. They are almost $3 a piece. The'yre grilles are also made of stainless I believe. Soon time Ill have it on the truck. By no means is my truck a show truck, more of a farm truck lol but you'll get the idea.
Old Feb 15, 2013 | 05:24 PM
Well, I did a quick install just so I could get an idea and honestly I dont like the fitment haha. Really hard to make that grille go with the contour of the grille surround. I'll step it up for the next one. (the 5/16 hex screws are not staying, simply just there to give the appearance of it being fully studded). Going to put 6" fogs behind the grille.
[IMG][/IMG]
[IMG][/IMG]
Old Feb 15, 2013 | 06:53 PM
RathF150's Avatar
looks cool
Old Feb 16, 2013 | 03:19 AM
Buxton91's Avatar
It came out great, but like I said man something inset would flow more with the body lines up front.
Old Feb 16, 2013 | 12:40 PM
Sweet. I definatly like it but agree with Buxton, it should sit in a little like the factory one, mabey with a slightly narrower border.
Old Feb 16, 2013 | 12:44 PM
Here's my custom lower to match the upper FX2 grille i have on my 05.
The 05 trucks basically had nothing down there from the factory.
Old Feb 18, 2013 | 08:55 AM
Nice! The front of your truck looks awesome.
Old Feb 18, 2013 | 09:13 AM
I do agree with you about how it would flow nicer if I made it recessed a bit and thats why the very first one I made, I did it that way. Our grilles are too small to do it that way if you ask me. I did the original with a 1.375" border and it wasnt for me. It didnt give off the bold look I wanted. Everyone has different likes right and I like the big dirty grilles you see on the newer ones so I made mine bigger.
Ill make another one in the next couple weeks and I will be doing it a little different.
heres a 99+ grille from rbp and I think it looks ridiculously small so imagine that same grille but with an even shorter height for our 97-98
[IMG][/IMG]
