2001 F150 starting problems
Old Feb 18, 2013 | 03:46 PM
mbhwest's Avatar
Starter turns over but no start up. Replaced battery, checked fuses. Took air filter off and shot starting fluid into it. The truck turned over for a second then died. Need help on where to trouble shoot next to get the truck running.
Old Feb 18, 2013 | 04:17 PM
Check for fuel pressure at the Schrader valve on the fuel rail. If it has pressure, rent/borrow a pressure gauge from a parts store, it should be at least 28 psi.
No fuel pressure could be a bad fuel pump, tripped inertia switch, blown fuel pump fuse, bad fuel pump relay, or plugged fuel filter.
