wheel Adapters
Old Feb 18, 2013 | 12:48 AM
MIKE 04 GT's Avatar
wheel Adapters
to be spacific i am talking about the hub sentric, with new wheel studs, not the spacers with out wheel studs. I know some say they are not safe, but my wheels have a back spaceing of 4.5", i am wanting the 1½" wheel adapters to push my current wheels ( Micky Thompson clasic 2) out so i can reattach my E brake Cable, and to get the tires outside the fender well alittle. will they be and harder on the front ball joints, tie rods, EXT. than a wheel that pushed my tires 1½" further out from where they are now? i like my wheels that i have now. I would think that one will be just as hard on the front end as the other. I am not taking about the Spacers that just push out your wheels by shorting up the threads on your lug nuts, but the ones with new lugs are the one i am talking about. what are your opions?
Old Feb 18, 2013 | 01:08 AM
pizzaman711's Avatar
While those are the "safest" out of wheel spacers, trying to get 3" of backspacing is going to wreak havoc on the bearings. And you'll still have to trim a little off the studs to get them to fit.
Why can't you attach the cable?
Old Feb 18, 2013 | 03:33 AM
JMC's Avatar
JMC
25 Year Member
I have a 10" wheel with 4½" back spacing and 305 70 R 16s. Brake cable doesn't rub.
Old Feb 18, 2013 | 04:05 AM
JMC's Avatar
JMC
25 Year Member
Double post
Old Feb 18, 2013 | 08:11 AM
MIKE 04 GT's Avatar
cable is to short, i am runniing 17x9, w/ 4.5 BS, with a 35-12.50-17 toyo mt. my previous tire was a 315-70-17 Mickey thompson ATZ, and i had no problem with them. i will be going to a 37 later. what wheel size, and back spaceing choice are the guys that are running 37? I figured someone running a 16x12 wheel with a BS of 4 or even 4.5 would be harder on the front end parts, correct me if i am wrong though.
Old Feb 18, 2013 | 08:12 AM
MIKE 04 GT's Avatar
If i could go with only a 1" adapter, i would.
Old Feb 18, 2013 | 10:45 AM
How is moving the wheel out going to make the cable reach? I'm just confused on that part.
And wheel width for the 37 depends on how wide it is, it could be anywhere from 9-12" wide generally.
Old Feb 18, 2013 | 11:44 AM
MIKE 04 GT's Avatar
The Cable Reaches, but with the wide tire I had to disconect it due to the cable rubing the inside of the tire. the Toyo side lugs will rub the cable and lock the e brake down
Old Feb 18, 2013 | 11:56 AM
MIKE 04 GT's Avatar
http://www.ebay.com/itm/4-PC-FORD-F1...31d31e&vxp=mtr
These are the ones i am taking about
Old Feb 18, 2013 | 01:41 PM
lltoolj02's Avatar
Well if your gonna run wheel spacers those are the ones to get with the wheel centric part. As long as they fit your Mickey T's center bore. You get the extra sturdiness of that wheel centric part as well as the lug centric part.
While i do run 1.5 adapters and love them. I can not recommend them to anyone.
Old Feb 18, 2013 | 03:29 PM
Is your cable not bolted along the lower control arm? That's the mine is and I've never had a problem, I never heard of anyone having that problem ha.
Even when I had 16x12's with 4.5" of backspacing and 35x14.50 thornbirds which have massive side lugs I didn't have that problem.
Old Feb 18, 2013 | 04:54 PM
Dog'em's Avatar
Like the others have stated, not sure how this is going to fix your e-brake issue but if you go with the adapters make sure they fit without cutting off your studs or replacing them. I have adapters on my 05 and 2 inch is the smallest spacer you can go without shortening your oem studs or replacing them with shorter ones.
Old Feb 18, 2013 | 05:30 PM
1.5" spacers will need shortening of the stock studs, they're like 1.6ish inches iirc.
Old Feb 19, 2013 | 01:21 AM
Buxton91's Avatar
Do you have pics of the issue?
Old Feb 19, 2013 | 11:09 AM
MIKE 04 GT's Avatar
No i did not take picures, i have the cable removed right now, so pic my not even help. I need less backspaceing on my wheel to push my wheels out to prvent the cable hitting.
