View Full Version : 1997 - 2003 F-150
- 97f150 2wd with rear abs brake and abs warning lights
- Help with dimmer switch wiring harness.
- 98 f150 4.6l auto trans 4x4
- Transmission
- I have some bad engine trouble but idk what the deal is.
- Speedometer
- Good ol GEM Module
- 2001 5.4 reoccurring lean codes
- Before I think about do anything
- Lift Kit question
- Will changing bad spark plugs and coils fix rotten egg smell?
- Are Rancho Shocks any good?
- 2003 f150 5.4l cranks but no start
- 1998 f150 v6 4.2l transmission problem
- Leaking Head Gasket - OPTIONS?
- 1998 blower relay wiring
- Intake manifold/ crossover pipe
- C Notch info?
- Does anyone know what part this?
- Broken Upper Control arm but.
- Battery saver relay has a jumper wire installed
- Misfire
- Battery Light Intermittant
- 1997 f150 odometer gear...
- Front diff oil
- Connecting Aftermarket DRL's
- Happy Fiddy Friday!!
- 5.4 propane leak test on vacuum lines questions
- Noise When Braking at Low Speeds <10 MPH Coming to Stop
- 2001 F150 Lariat automatic seat swap with Expedition
- 1999 Fuel leak - easiest way to fix?
- 4.6 2v triton Power gains + using 2v GT parts compatible?
- Cylinder 3 misfire code P0303
- 1997 F150 4.6l no crank
- Will failing transfer case relay illuminate check engine light, or 4x4 lights?
- 01 F150 never ending coolant issues
- Trying to pin point starter issue
- Driving me crazy, cannot move my truck
- Could use some help with my 97 lariat 5.4
- Transmission cooler line connector size
- Ground Strap and Bracket Location
- 99 f150 back door swap
- 2001 fuse #5 keeps popping
- Catclamp installation
- Truck stumbles
- 1998 F150 4.6 runs when it wants to
- HELP! Buying a 97 150
- 4r70w sometimes no reverse
- IAC Valve Testing
- 97 Lariat
- 1999 f150 4.2L v6 at 350k - unknown rattling sound?
- Rough idle, out of ideas
- Shifting hard into 2nd gear
- 2002 5.4 supercharger
- Fan clutch question
- Tailgate hinge cup rusted off. How to fix?
- Won't start
- Head or time
- 97 f150 lariat no spark
- Replacement Step Pad '03 Supercrew
- No ground to driver's window motor plug 99 F150
- 4.2L V6 Overheated - no coolant loss
- 2001 XLT not starting, doesn't recognize its in park, won't crank
- 99 F150 4.2L daunting task. Help please
- 97 F150 AC Pressures
- ISO front springs 1998 F150 NASCAR edition.
- 6 lug Conversion. Wheel Adapters. Will they Work?
- Shroud Label Picture
- Fuel Rail on top of the injectors
- 2000 F150 spark plugs
- 2003 F150 5.4 FALLS falls on face timing shows retarded
- Driver window inop, relay clicking
- 1997 F150 4.2L No Crank No start issues. (Head scratcher)
- 02 f150 4.2l
- What is this
- Running rough
- Electrical
- 5.4 2 valve coolant leak
- 2001 Center Cap on 1999 model truck
- 1998 F150 4x4 4.6l fuel pump power issue
- 2000 Ford F150 Transmission to Radiator Lines
- 02 super cab body swap on to a 12 frame
- Wiring diagram for pcm switched power- 2001 supercrew 5.4L
- 2001 5.4 loss of power
- Help needed with 98 f150 4.6 4r70w issues
- Front Suspension Tips
- Almost to the finish line!
- Speed limit removal
- EGR Vacuum Reservoir F75Z-9E453-AA
- starting problem
- Rear pinion seal
- Hood/ditch light brackets
- Coolant running hot and escaping from radiator cap
- 98 f150 drag/Street truck bbf
- p0161 code
- Intermittent Shake at Speed
- How much does a 98 roush stage 1
- Lifted front end sagging??
- Rusted Frame / Rockers
- 2003 F150 Heritage
- Steering problems
- About to use truck to tow
- Need help
- engine swap. need some answers please
- Frame / Chassis number
- F150
- Help - 2002 Lariat 5.4L SuperCrew - Keeping it for Son
- 2wd 2002 4.2 f150 302 engine swap questions
- Check Engine Light
- New to me Truck!
- Help me please
- 03 4.6 SC wire Harness Removal question.....
- Need New Seats
- ABS Pump / hard brake line route.
- 2002 f150 fuel rail help
- Power windows
- EGR/DPFE problem
- ‘99 f150
- Hoping someone can identify 2 items ‘02 F-150 5.4L
- Not sure exactly where the main issue lies!?!?
- 1998 Ford F-150 misfire on acceleration
- water pump replacement shopping list
- '97 4.2 Water Pump Change issues.
- 5.4 swap help!
- running rich, black smoke
- 2003 f-150 4.2l v6 remote start
- The Mystery Splash Guard | WTH?!?
- How Many Catalytic Converters does my truck have?
- I have worked on this for ever
- Fuel line issue?
- High fuel trims at idle and load
- Battery Cable Teplacement
- 2003 Ford F-150 5.4L Rattling/Grindy noise at 2,000+ RPM
- 2001 F-150 Heater Hose & Vacuum Line diagrams
- Going to change heater blend door, does anyone know what this part is
- Getting higher MPG
- Please help....
- Dash only works if interior light on using dimmer switch
- Revved Engine Stays Revved w/Clutch Depressed
- best way to remove old fuel from 2002
- 97 f150 4.6
- Valve cover self cover gasket replacement
- Anyone ever install a heater bypass valve?
- 2002 e150 Headlight socket wiring
- Aux Trans Oil Cooler Line Connection Question
- 97 4.6 2 valve
- Help me
- horn sounds for no reason
- Will a 80mm MAF from a 1998 Lincoln Mark III fit on my truck?
- Will Trade A Funny, Funny Story for Advice
- F8UZ-7A194-AA Pan
- Installing a 5.4L Lighting Engine in 2003 F150
- My Dad Passed & Left Me His 2003 F150
- no heat
- 2000 F150 good to buy?
- 97 FORD F150 ENGINE 4.6 replacement
- "Muffler hole" Noise From Engine/Underhood Area
- Engine Not Heating Up
- No cold start idle with my 1999 F-250 5.4Ltr
- 2000 sas questions
- Replaced Worm Gear, Gauges not working
- 12Volts on both wires on fuel injectors
- 97 ford f150 4.6 liter five speed 4x4
- Broken HVAC
- Fog Lights Help
- Patman and Fiddy history
- Starter replacement advice?
- 99 F150 4×4 problem
- Window regulator hitting lock mechanism housing
- Will a 4.6 run with broken timing chain 99 f150 4x4
- 1998 F150 Speedometer Calibration
- Backup camera wire routing tips?
- 97,4.6, f150 hessation at 40-50 mph
- 1998 F150 4x4 issue
- Rebuilt Starters from Napa: The Curse that Keeps on Giving
- 1997 f150 horn blows when door opened
- Idle Rises when depressing clutch: Solution
- My V10 F150 is finally getting some love
- Bed to Cap boot
- Shorted door locks horns stuck on!!
- 2000 f150 lean codes
- 1997 supercab leak
- 2001 f150 4.6l no start
- Howdy
- Dash fuel level on 2000 CNG.
- Clunk in transmission / torque converter when coasting only at highway speeds
- Driveline
- Truck takes forever to warm up
- 1997 4.2 V6 F150 - long/short block source
- 4 Low, no dash lights
- Timing chain replaced - Pics - Guess what side adjuster was bad ?
- instrument panel, light over lcd area is out
- Capt. Kirk
- Front Hub Axle Nut P/N??
- 2000 7700 Series F150
- CanBUS Control on 2003 f150
- Morimoto 2Stroke 3.0
- fordman66
- 98 F150 Both Power locks don't work
- issues with steering system
- Blower motor and beeping sound
- Rear end swap
- P0135 and P1135 codes - questions
- Cruise Control Diagnosing
- 2001 and newer Radiators.....
- EATC will not control the temperature
- BW4406 tear down.
- heater/water pump restrictor
- 4r70w - How many miles on yours without rebuild/replacement
- 2001 4r70w AT - Best Fluid ?
- 2001 f150 rwb speedo problems
- Engine replacement
- 2000 F150 XLT Auto lamp install
- 1997 F150 4.6l engine swap to 2005 4.6l out of Mercury Grand marques
- 4x4 F-150 will not engage
- heavy rain storm
- fuel pressure test port ..SPECIAL
- 1999 Super Cab, Lock Switches/Window switches not working properly
- Fix for fuel gauge?
- 03 wheels and tires upgrade
- 01 f150 shutting off with heavy braking and Rev.
- 2001 - 5.4l 2-valve engine - whine/noise at cold start
- Stock am/fm/cassette stereo Issues (2)
- 2003 4.2l Limp mode
- Fuel Pump Driver Mod for 2000 7700 model
- Sad story of a '99 4.6
- Husky floor liners
- Bad starter/battery ground cable
- My e-brake light stays on?
- Tricking sound 1998 4.6L F150
- 2003 F150 Leaking ABS Modulator Valve
- 98 F-150 4.2 idles fine take gas fine for 10 or 15 seconds
- 2002 f150 4.6l Parasitic battery drain and PATS issue
- Replacing part a truck that has been sitting.
- 2001 5.4l engine - ever so slightly rough at idle or when stopped and in gear
- M5R2 parts
- No start, kinda cranks then stops.
- 97 f150 5.4 motor/trans compatibility
- Flushing radiator
- Headlights go out while driving
- Cleaned my truck's IAC valve
- 4.2 to 4.6 engine conversion
- 4r70w Automatic Transmission
- speedo green light on but "mileage is not changing when driving"??
- 1997 5.4 brake line issue
- Does is matter? MERCON, MERCON V
- 97’ f150 not going over 40
- drop crossmember
- Yellow plunger thing in bottom of tranny pan
- GEM Issue??? Among many other issues
