Fuel Pump Driver Mod for 2000 7700 model
Old Oct 19, 2020 | 04:39 PM
wrader1's Avatar
Question Fuel Pump Driver Mod for 2000 7700 model
I have a 2000 F150 7700 4x4 extended cab. This model has a special towing package with larger leaf springs, air shocks, etc.. I am trying to locate the fuel pump driver module (fpdm) which is normlly located above and in front of the spare tire. This model is configued much different that a typical F150 and the fpdm is not where I waas expecting it.
Old Oct 19, 2020 | 04:42 PM
projectSHO89's Avatar
Stop expecting to find one, it doesn't exist. Those started for the 2004 MY for the F150.
Other than the suspension and axles, it's a standard F150.
Old Oct 19, 2020 | 04:48 PM
wrader1's Avatar
Ok thanks but I have seen Youtube videos for the 2000 and 2001 regular models and they are there, where I explained. If this model does not have one, then something else must be causing the problem of fuel pump not pumping and truck not starting. I had replaced the fuel pump and relay about 30k miles ago. I was hpoing that was the problem again.
Old Oct 19, 2020 | 04:51 PM
Have you confirmed with a pressure gauge the fuel pump is not working? Have you reset the inertia switch?
Old Oct 19, 2020 | 04:55 PM
wrader1's Avatar
I checked the reset switch and seems OK. Not checked pressure but did replace filter. And can't hear the pump sound when I turn key on. Assumed it was the driver module.
Old Oct 19, 2020 | 06:27 PM
Nope, that's the pump or a wiring issue. Instead of using a FPDM, your system is a constant run return system with a FPR on the rail.
Old Oct 19, 2020 | 06:43 PM
wrader1's Avatar
Thanks. I will check the relay and fuse. If those are good I guess it is likely the fuel pump.
Old Oct 19, 2020 | 09:07 PM
There should be some checks you can do with a multimeter to make sure before you drop the tank. It could be something as simple as a bad wire or ground.
Old Oct 20, 2020 | 06:38 AM
No, they're not. See previous.
Old Oct 20, 2020 | 12:39 PM
Bluegrass's Avatar
There is no fuel system control module on your truck.
It is a two pipe system.
Pump in the tank powered through a relay under PCM control as long as the motor is running and runs the pump a few seconds at key on, before cranking to pre- prime the fuel rails for quick starting.
Fuel pressure regulation is done on the fuel rail to reduce pump pressure to about 35 psi. The rest is returned to the tank through a return line.
The equipment you see back at the tank area is all for the EVAP system testing for a fully enclosed fuel tank system for emissions.
You came here to ask, LISTEN.
What you may have saw on youtube is either your mistake or the maker of the video misspoke somehow..
