4r70w Automatic Transmission
I have a 2001 ford f150 supercrew 5.4l 4x4 with the 4r70w Automatic Transmission.
I received all the maintenance records from the Original Owner when I purchased the truck.
The last transmission service as about 8000 miles ago. I called the Transmission Service Shop that did the work to find out what transmission fluid they used.
On the Service Order it reads: "Synthetic ATF SP324".
The owner of the shop said that "Synthetic ATF SP324" is a Universal Synthetic Transmission Fluid sold by: Service-Pro and That it can be used in many transmissions.
I have Not towed with this truck yet and it seems to shift fine when driving the truck around town and on the highway.
I Am Planning to tow a bumper pull trailer that weighs around 3500lbs, the distance of about 2200 miles here in a couple weeks.
I have some fear about the Current ATF in the truck and along with our 4r70w to be known to be troublesome (from what I have read on Ford F150 Forums) I am thinking of changing the ATF before this tow.
With all this in mind..... What Brand ATF do you all recommend? (I know it requires Mercon V)
Is all Mercon V fluids the same, just as well made, no matter the Brand?
Price Wise the Walmart brand Super Tech is the least expensive. Is: Supertech Mercon V just as good as a more expensive Brand of Mercon V?
(I want to do what ATF is Best for this Not well talked about Transmission)
Thank You
Thank You
Service-Pro doesn't give part numbers on their site. Here is what they have, along with Mercon V compatibility:
https://service-pro.com/products/lubricants/
If it's any one of those that says YES, I'd leave it alone.
Now, if cost is no object and you want the BEST transmission fluid out there, get this:
https://www.amsoil.com/p/signature-s...ion-fluid-atf/
That's going to cost a pretty penny, you would need about 14 quarts with a torque converter drain.
Global Full Synthetic Multi-Vehicle ATF YES
Multi-Purpose ATF NO
Multi-Vehicle Syn Blend ATF YES
Mercon V* YES
Full Synthetic ATF* YES
Full Syn SAE 50 Manual Transmission* NO
Dex VI* NO
On the phone today the owner said they use "Universal Synthetic" ATF Fluid on ford f150, sold to them by: Service-Pro.
* He Actually said "Serve Pro" on the phone but I could not find a Serve Pro anywhere online.
On the Service Bill it reads: "Synthetic ATF SP324"
**Is the Super Tech Mercon V from Walmart just as good as any other Mercon V?
I will Trust that the correct ATF was installed in this trucks transmission.
